leskzn Posted April 7, 2015 Share Posted April 7, 2015 Hi does anybody know how to connect a Boss GT 100 multi effects through a spider jam amp . Thanks Les Quote Link to comment Share on other sites More sharing options...
rarellano Posted April 7, 2015 Share Posted April 7, 2015 I've read that a good input to use these kind of devices is "CD/MP3" input. Also, you can connect your pedal to "AUX" input. because guitar input ALWAYS has some effect. 1 Quote Link to comment Share on other sites More sharing options...
Brazzy Posted April 7, 2015 Share Posted April 7, 2015 (edited) Hi does anybody know how to connect a Boss GT 100 multi effects through a spider jam amp . Thanks Les I like to use the Aux input so I can add some delay and reverb. Sounds great using the HD500. I've noticed that when I plug into the Aux input I must make sure I have the record set function set to Mic otherwise I get the amp models. I know it sounds weird but that's the way mines been working. I can also the tone stack for the AUx input to shape the sound like a global EQ. The CD input works good also since it has no effect whatsoever. The only issue I can see with the CD is that it's a weak 1/8" input connecter which can cause issues. The 1/4" connector is much better. I also use the guitar input sometimes using the "green" Clean model and add some delay and reverb with the tone stack set to 50%.along with the drive and volume. With the HD500 I run the left mono 1/4" out into the Aux or Guitar input with the pod set to either "combo front" or "studio direct". I create my patches with the pods master at 50%, Edited April 7, 2015 by Brazzy 1 2 Quote Link to comment Share on other sites More sharing options...
