Peeler Posted April 8, 2015 Share Posted April 8, 2015 Happy Wednesday! I am a lover of the HD500X - been crafting some tones for my original music and coming up with some stuff I am very happy with! I am struggling a touch with the 'Pitch Glide' - my problem is I am finding it to be not very 'gradual' or even with 'Whammy' type of sweeps from pitch to +12 or +24 when using an expression pedal. A dramatic pitch change happens much closer to the 'Toe Down' position rather than an even 'sweep' from 'Toe Up' to 'Toe Down' Settings on the Exp pedal are for instance '0' pitch at Toe Down and +12 at Toe Up I am using an Ernie Ball VP Jr with an active pot - also tried the Boss FV500 - wondering if anyone can shed some light if they have had better luck with this effect. Thanks! Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted April 8, 2015 Share Posted April 8, 2015 do you have the same issue with the onboard pedal? I was actually pretty happy with how the sweep moved on the Pitch Glide, but I pretty much only use it as a static-interval harmonizer without a pedal engaged or for two-octave simulated tape-stop effects. Quote Link to comment Share on other sites More sharing options...
Palico Posted April 8, 2015 Share Posted April 8, 2015 I've found the Pitch Glide can be a unpredicable beast myself, but the original one was too, even the mix control seems to not work logically. I mostly use it by putting it an seperate chain and set mix to 100 it works differnetly than putting inline with mix 50% although logically those should be the same. Like gunpointmetal said you can elemiate the pedal itself by putting on the onboard pedal. Quote Link to comment Share on other sites More sharing options...
NinoScholz Posted April 8, 2015 Share Posted April 8, 2015 My main problem with pitch glide is the pedal calibration is constantly changing on me. So all the way down may be 0.5 instead of zero, rendering me out of tune until i re-edit the patch. I've calibrated but it seems to happen soon after. Maybe i need a new FBV. Quote Link to comment Share on other sites More sharing options...
BlueViolince Posted April 8, 2015 Share Posted April 8, 2015 Here's a link to upvote my ideascale suggestion for switchable linear/log taper on the expression pedal. Clicking the link will upvote, FYI. http://line6.ideascale.com/a/dtd/Pod-HD-500-500X-expression-taper/714268-23508?submitted=1# Quote Link to comment Share on other sites More sharing options...
duncann Posted April 8, 2015 Share Posted April 8, 2015 My main problem with pitch glide is the pedal calibration is constantly changing on me. So all the way down may be 0.5 instead of zero, rendering me out of tune until i re-edit the patch. I've calibrated but it seems to happen soon after. Maybe i need a new FBV. If you're talking about the exp pedal on the pod, try tightening the allen bolt very slightly before calibration. This will help keep it in place for a longer period of time before it loosens again and starts to fall under its own weight. 1 Quote Link to comment Share on other sites More sharing options...
NinoScholz Posted April 9, 2015 Share Posted April 9, 2015 If you're talking about the exp pedal on the pod, try tightening the allen bolt very slightly before calibration. This will help keep it in place for a longer period of time before it loosens again and starts to fall under its own weight. Thanks i 'll try that - it's on the FBV controller but must be similar pedal i'd think Quote Link to comment Share on other sites More sharing options...
