HD500x - Tuner mode disables global eq
Ruben40
Could anybody confirm my problem ?
I have a problem with the not working global eq at the 1/4" outputs.
When I power up my hd500x then first the global eq is working. I use the low-cut at 1kHz to hear the active eq .
But after I activate the TUNER and deactivate it ,the global eq is disabled.
After rebooting my pod the global eq is working again.
I made a global reset after firmware update !!!
LOL...if it is a bug, it's a doozie. Since the two functions have nothing whatsoever to do with each other, I suspect it would have taken me a while to put two and two together. Good thing you noticed the connection. Gonna give that a try tonite, see if mine does it.
