Ruben40 Posted April 8, 2015 Share Posted April 8, 2015 Could anybody confirm my problem ? I have a problem with the not working global eq at the 1/4" outputs.When I power up my hd500x then first the global eq is working. I use the low-cut at 1kHz to hear the active eq . But after I activate the TUNER and deactivate it ,the global eq is disabled. After rebooting my pod the global eq is working again. I made a global reset after firmware update !!! Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted April 8, 2015 Share Posted April 8, 2015 It could well be a bug so I recommend you raise a support ticket with Line 6 so they can fix it. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 8, 2015 Share Posted April 8, 2015 LOL...if it is a bug, it's a doozie. Since the two functions have nothing whatsoever to do with each other, I suspect it would have taken me a while to put two and two together. Good thing you noticed the connection. Gonna give that a try tonite, see if mine does it. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted April 8, 2015 Share Posted April 8, 2015 In this thread http://line6.com/support/topic/13056-global-eq-am-i-doing-something-wrong/ Digital igloo has confirmed they have a fix for the reported Global EQ issues that will be released as fw 2.62. Quote Link to comment Share on other sites More sharing options...
