Sign in to follow this
Louiepalooza
Drop to 432 Hz in Workbench HD
Looking for the ability to use 432 Hz as an alternate tuning in Workbench HD. I have been poking around and I have not been able to find a way to do this. Does anyone have any input on this subject? I am accompanying an amazing female vocalist that uses 432 in some of the songs she does. It would very beneficial to be able to go back and forth between the different tuning she uses and only use 1 guitar.
You can use Parallel Pitch to finetune the tuning of your guitar.
The problem with this is that you can't turn it off on the patch, unlike the alt tunings on the alt tuning knob, so you have to use a slot on one of your custom banks.
Enable Parallel Pitch, set all Pitch's to 0, put al Mix to 100%, then adjust Cents to desired fine tuning for all strings.
  • Thanks 1
