defectdesigner 0 Posted April 21, 2015 Hello guys, I was looking for such a topic, but could not find. If it exists, please give me a link and kill this topic.. Just bought a new POD HD500X. Could you tell how can I mute one channel entirely? In presets I have 2 parallel amps, and mixer, 100% left and 100% right, one amp gets muted by a control. Output goes from unbalanced channels to amps. I use it on live gigs, had Morley di box before. When I press the control on POD HD500X, I still hear the clean sound from the muted channel. Could you tell if you know how to make it properly? Maybe you have a tone with such function? Thanks! Quote Share this post Link to post Share on other sites
spaceatl 1,976 Posted April 21, 2015 +1 If you hook up to edit and select the Amp Button...you can turn the Amp(s) off and set the Bypass Volume there also.... 1 Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted April 21, 2015 thanks, found! ) sorry to bother could not see it because you have to switch the amp off to see the bypass signal separately ) Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted May 2, 2015 works nicely, but sadly there is a little delay, click, when I step to mute one channel.. is there a way to have 2 channels without "amps" from POD HD, - use it only for effects, and mute one channel (0 bypass on one channel after pressing a footswitch) - to use preamps from real amps? Quote Share this post Link to post Share on other sites
pfsmith0 228 Posted May 2, 2015 Perhaps use a volume control FX set to 0% and turn it on/off with one of he foot switches. Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted May 5, 2015 There is still bypass signal when I do like this.. Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted May 31, 2015 When using POD's preamps, but there is a lag between the click of a button and actual effect. You stop on the button and it takes some milliseconds till the channel gest muted or unmuted. Sadly it it not instantly and it spoils some of the effect if the music is fast.. Any way to overcome this? Quote Share this post Link to post Share on other sites
pfsmith0 228 Posted June 1, 2015 If your "click of a button" is going from one patch to another then yes, there is a light delay. This has caused me to switch to FS1-8 mode. With that, the switches only turn on/off FX which, to my ears, cause no delays. This is much more usable to me. Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted June 3, 2015 No, the thing is it is not going to the other patch... with the button also in the preset some buttons stop working as they should have Quote Share this post Link to post Share on other sites
brue58ski 642 Posted June 3, 2015 What I do is assign each amp's Channel volume to the same expression pedal. Then make, for example, Amp A's Minimum position 0% and and Amp B's Minimum position whatever Channel Volume you want it to be. Then reverse for the Maximum position. Amp A's Maximum position the Channel Volume you want it to be and Amp B's Maximum to 0%. So as you go from Minimum to Maximum and vica versa, one amp is turned up and the other amp is turned down. Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted June 3, 2015 I attached my setting, if you change .txt to .5xe, it should work. if i haven't confused anything. can you attach yours? Diskord Stereo.txt Quote Share this post Link to post Share on other sites
brue58ski 642 Posted June 3, 2015 I attached my setting, if you change .txt to .5xe, it should work. if i haven't confused anything. can you attach yours? I think you were asking me. Here it is. I did this with no HD500X hooked up so I haven't tested it yet. One possible problem is you need to have an extra expression pedal hooked up, Otherwise, if you only use the internal expression pedal, when you engage the Wah pedal, Amp A will be the only amp on until you switch back to EXP 2. Haven't had time to trouble shoot this issue. One possible solution would be to assign the Wah to one of the numbered footswitch. Not ideal but I can't think of any other way right now. Quote Share this post Link to post Share on other sites
defectdesigner 0 Posted June 3, 2015 I think you were asking me. Here it is. I did this with no HD500X hooked up so I haven't tested it yet. One possible problem is you need to have an extra expression pedal hooked up, Otherwise, if you only use the internal expression pedal, when you engage the Wah pedal, Amp A will be the only amp on until you switch back to EXP 2. Haven't had time to trouble shoot this issue. One possible solution would be to assign the Wah to one of the numbered footswitch. Not ideal but I can't think of any other way right now. Thanks! Will test with POD tomorrow. It looks same as my previous preset, you based it on mine? Quote Share this post Link to post Share on other sites
brue58ski 642 Posted June 3, 2015 Thanks! Will test with POD tomorrow. It looks same as my previous preset, you based it on mine? I changed your preset and didn't rename it. Other than taking out the Volume pedal you had, the only changes were in the Controller section. Each amps Channel Volume assigned to Exp2. Quote Share this post Link to post Share on other sites
