kiki_90291 Posted April 24, 2015 Share Posted April 24, 2015 I'm using an iPad 2 with the latest iOS version. I lose the Bluetooth connection with the Firehawk constantly - it's really annoying. The iPad claims to be connected, but the app doesn't see the Firehawk, I have to kill the app and restart it to get the link to reboot. Is anyone else having this issue? Quote Link to comment Share on other sites More sharing options...
kiki_90291 Posted April 24, 2015 Author Share Posted April 24, 2015 I just realized my unit sits a few feet from an Apple Airport Express. Could this be interfering with the Bluetooth connection? Why would the ap lose the connection, but not the iPad? Quote Link to comment Share on other sites More sharing options...
Phaze11111 Posted April 24, 2015 Share Posted April 24, 2015 I'm also using my new Firehawk with an iPad2 and the latest iOS version too. I'm having the same problem kiki_90291 is describing. Any suggestions to fix this annoying issue? Quote Link to comment Share on other sites More sharing options...
bneub111 Posted April 24, 2015 Share Posted April 24, 2015 I am having similar problems. First time I plugged it in, no problems. Next two times had the same Bluetooth problems listed above. Last night it worked great. It has been sitting in the same spot, connected to the same equipment each time. The tones are great, it's easy to use, need more bass guitar specific amps and effects. Quote Link to comment Share on other sites More sharing options...
cdowdy Posted April 24, 2015 Share Posted April 24, 2015 I have a similar problem but with an android device, I can pair the two together and select it as a device in Amplifi Remote, but the FH does not show on the list of devices on the main screen. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted April 24, 2015 Share Posted April 24, 2015 Try going to your bluetooth settings on the ipad and forget device, then set it back up as though it's the first time syncing, might help, might not Quote Link to comment Share on other sites More sharing options...
jag84325 Posted April 28, 2015 Share Posted April 28, 2015 I have an android tablet and i can connect witht he firehawk but it will not let me get into the edit mode. It just keeps kicking me back to the effects screen. Anyone else having this problem? 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 28, 2015 Share Posted April 28, 2015 What do you mean by the effects screen? What do you see? Quote Link to comment Share on other sites More sharing options...
jag84325 Posted April 28, 2015 Share Posted April 28, 2015 It is showing my tones and also the effects from the firehawk but when I try to go to the edit mode in just thinks for a few seconds and it goes back to the effects Quote Link to comment Share on other sites More sharing options...
jag84325 Posted April 28, 2015 Share Posted April 28, 2015 My friend how has an Ipad can make it work just fine. Is it just an android problem? 1 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 28, 2015 Share Posted April 28, 2015 I think you are already in edit mode. If I understand correctly, the display shows the FX. Try touching one of the visible FX. It's parameter screen should appear, and you can edit the parameter settings. Quote Link to comment Share on other sites More sharing options...
jag84325 Posted April 29, 2015 Share Posted April 29, 2015 Yes thats the problem....I touch the fx and it doesnt go to the parameter screen just thinks for a minute and comes back to the fx. A droid issue? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 29, 2015 Share Posted April 29, 2015 Probably a droid issue. Is your droid on the list of supported Android devices? http://line6.com/firehawk-fx-multi-effects-pedal/specs/ Quote Link to comment Share on other sites More sharing options...
relfaithsp Posted May 24, 2015 Share Posted May 24, 2015 My Firehawk also keeps losing the Bluetooth Sync. I have tried it with an iPad Retina Display with the latest iOS, and I have also tried it with my Android Samsung Galaxy S5 and I have the same problem with either sync. It appears to be a poor bluetooth in the Firehawk, and not related to the Android or the iPad. I need this fixed immediately. Quote Link to comment Share on other sites More sharing options...
lefttygtr Posted May 25, 2015 Share Posted May 25, 2015 I have tried my iPad 2, galaxy tab and both drop Bluetooth. My iPhone 6 is the only device that seems to work the best but it also has lost connection but very rarely. I know there is a software update coming soon to fix the problem. Quote Link to comment Share on other sites More sharing options...
meuste Posted May 25, 2015 Share Posted May 25, 2015 I just unboxed my Firehawk Saturday and took care of the preliminaries. It hooked right up to my Android Dragon Touch M8. I have edited a few patches so I know it works. I haven't saved anything though. Will get more time to fiddle next week. Tried the tone finder and that worked too. No connection drops so far. The Dragon Touch is not on the list and still works. Quote Link to comment Share on other sites More sharing options...
MikeLeZoo Posted May 26, 2017 Share Posted May 26, 2017 I've had my Firehawk FX a week now and can't keep a connection via my Galaxy S7 :( I did plan to buy a second hand tablet to run it, but I can't a response from the link above of supported devices. Does anybody have a definitive list, or know it's where abouts? Ta M Quote Link to comment Share on other sites More sharing options...
JamieCrain Posted May 26, 2017 Share Posted May 26, 2017 Same for me. IPad 2 on a stand right above the firehawk. The Bluetooth connection drops out a lot, and the Bluetooth light on the fire hook flashes. Then when it reconnects, it re-syncs everything. As a side note, with an iPad 2 you can't have the latest iOS version. Apple gently encourages you to upgrade your device to access that! Quote Link to comment Share on other sites More sharing options...
Dehzzyy Posted May 27, 2017 Share Posted May 27, 2017 My fire has no issues! Quote Link to comment Share on other sites More sharing options...
