adamshirley Posted April 27, 2015 Share Posted April 27, 2015 When i press the D or TAP button, it will switch between the 2. so if i press the TAP the D will activate or vice versa. The COMP and Delay buttons do the same thing. also the tuner does not work. I can hold the TAP button and the tuner will come up, but it doesnt register anything when i play a note. any ideas what is going on here? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 27, 2015 Share Posted April 27, 2015 This could be either corrupt firmware or a hardware problem. First I would try reinstalling the firmware. Make sure you back up your bundle of presets to restore later. If the problem persists it is probably hardware. Since several switches are affected I think it's probably an internal wiring issue rather than multiple switch failures. Inside the device there are several little plastic couplers that join certain chip components together. Sometimes symptoms such as you describe are the result of these little couplers coming loose or being disconnected. If you are not comfortable doing this inspection yourself you may want to have the device inspected at an authorized service center. Quote Link to comment Share on other sites More sharing options...
