kimdrawlings 0 Posted May 7, 2015 Any suggestions on how to normalize the preset volume across presets. One idea of mine is to use the compressor and add or reduce dB to get to the same volume. I think that it can be turned on in the preset and can be done without assigning it to a footswitch position. Any other ideas? Quote Share this post Link to post Share on other sites
mcbeddall 109 Posted May 7, 2015 How about "volume" and "master" in the amp settings? Or are they altering the tone too much? Quote Share this post Link to post Share on other sites
kimdrawlings 0 Posted May 7, 2015 Volume and Master definitely alter the tone. Looking for another solution. Quote Share this post Link to post Share on other sites
bond19 21 Posted May 7, 2015 use the effects loop with extra cables, once you start switching between your presets, it is easy to bring the db up and down(send), leave the mix at 50% Quote Share this post Link to post Share on other sites
mcbeddall 109 Posted May 7, 2015 Sounds like it needs a mixer section like in the 500, zoom g5 also has a master output level for each patch that doesn't alter tone If I were you I'd submit a request for something to be implemented in an update on ideascale I'll definitely vote for it I'd post it myself but I don't have my unit yet so can't really judge what exactly is required Quote Share this post Link to post Share on other sites
lefttygtr 5 Posted May 10, 2015 Part of the problem I see is the mix of HD and Non HD amp models. Now that we have both on the same system you can really tell the difference. To me the Hd model amp are much louder, I normally set my vol at around 60 or so. With the Non HD amp models I find I have to set the vol to 80 or higher. There are ways to work around this, setting up HD amp models at lower vol etc. The best way would be to have a mixer or dare I say global eq (it only took forever to get one for the Hd500). Quote Share this post Link to post Share on other sites
kimdrawlings 0 Posted May 13, 2015 After speaking with support, the volume setting on the amp within the app does exactly that without changing the tone. Firmware V1.1 is supposed to offer the ability to change preset volume with the volume knob on the Firehawk directly without having to edit the amp volume setting in the app. Issue resolved. Quote Share this post Link to post Share on other sites
bond19 21 Posted May 13, 2015 Yes, in version 1.1 you can adjust the patch volume with the large knob (in pink mode), but as I understand, you will still have to normalize each individual patch (either this way, or another), as there is not a global volume level setting. Quote Share this post Link to post Share on other sites
Duckie162 2 Posted June 15, 2015 Sounds like it needs a mixer section like in the 500, zoom g5 also has a master output level for each patch that doesn't alter toneIf I were you I'd submit a request for something to be implemented in an update on ideascale I'll definitely vote for itI'd post it myself but I don't have my unit yet so can't really judge what exactly is required This has to be in the ideascale submitted. i will vote for it. do you have a link.? Quote Share this post Link to post Share on other sites
bond19 21 Posted June 16, 2015 The big knob turned pink adjusts the master volume without altering tone. Quote Share this post Link to post Share on other sites
mcbeddall 109 Posted June 16, 2015 "The big knob turned pink" Almost choked on my cornflakes Quote Share this post Link to post Share on other sites
bond19 21 Posted June 16, 2015 "The big knob turned pink" Almost choked on my cornflakes Love it!! Quote Share this post Link to post Share on other sites
