Sign in to follow this
panaman
Jennifer Batten on Variax
just watching a truefire tutorial video 50 ultraintervallic licks u must know.
Jennifer Batten on Variax all the way through  hours.
not any noticeable tweaking unfortunately,but consistantly jjust great sounding stuff, aside from the playing which is awesome. great backing tracks as well.
there are samples :
which variax is this, or does it make a fifference?
wonder if  other vids of mrs. batten have the variax as well.
Custom paint job, replacement pick-ups, new whammy bridge.
What's that thing at the nut end?
Impossible to say if she's using the modelling or the custom pick-ups.
She uses it for tapping/sweep picking so that any accidentally touched strings are damped, but it can just be flicked up when you do want open strings to sound, back in the high gain 80's hair scrunchies and similar would be used for this but were not as even or quick to enable/disable
Cheater! lol.
Just kidding. Whatever tool works.
A great endorcement, she is a top notch player using a Variax is really something!
It seems to be a 69 body and neck with a 89F double locking Floyd Rose tremelo system.
She's also using some non standard pickups.
Great looking guitar!
Nice to see some well known top player using a Variax.
Of course, Adrian Belew has been using the Variax electronics in his Parker guitar for a long time.
The neck gotta be custom, the headstock doesn't match the 89f, plus the handwritten "Variax" on the headstock.
... plus the handwritten "Variax" on the headstock.
That's an upcharge of $75...$85 if you want it spelled correctly. :P
so it is not the stock variax i might afford, almost had my mind made up this morning...
No, it's a 69 body so it's definitely not a 89 neck. Wouldn't fit.
You're probably correct that it's a custom neck though, it doesn't look like a stock 69 neck.
No it's not.
The modelling will sound exactly the same though.
Seems it also has a Fishman tripleplay installed.
