Sign in to follow this
sethaldridge
Can't install USB Firmware 1.04
I am running a POD HD500X and the Line 6 Monkey is telling me I have a USB Firmware update from v1.01 to 1.04.
When I click Update Selection I get the following error:
Update failed.
0xfd from Server - Internal Server Error
Make sure the cables are still connected and try again.
Both my computer and device are authorized and I can connect to my device successfully.
Any thoughts?
ok line 6 issue as I just ran monkey on my UX2 to see if anything was new and it said I needed to reauthorize my addons (Changed MB/CPU) and it gives the same error 0xFD when trying to do so
I'm having this same issue with the usb firmware update on my 500X. At least I know it's a problem on Line 6's end and not mine now though.
Having the same issue.
First time I run it I get :
Pod HD Update Failed.
(Code 80002008) Client has been disconnected from the network.
Try the update again making sure the cables are still connected.
When I rerun the update I get the following:
0fxd - Server failed. Internal Server Error
Thanks!
I'm getting the same message. Tried several times and still no luck. I was hoping that I'd find an answer here.
Looks like everything is good to go now folks, I just successfully updated my usb firmware \m/
Hello!
I have a Drivers problem, it is not installed in my Notebook, I update the driver and it keeps the yellow triangle. Therefore I can not upgrade my POD HD500.
It is in "UPDATE FLASH".
Change the USB on my pedalboard to check for trouble and you do not recognize it ...
What can it be?
Thanks info or if someone had the same problem. Greetings.
I too am getting this error when trying to to update the Flash Memory via Line 6 Monkey. Help! Any suggestions?
On 8/12/2017 at 5:34 AM, backflash said:
What did u do to fix it
Hello Guys
I have a problem that same with this,
is there anyone can help me with this?
Update failed.
Any thoughts?
