Assigning FX to a Footswitch
morelia
*Which is yet another reason why I think a portable option for EDIT needs considered*
If you don't feel comfortable with working on the machine itself, and you just want to make minor changes...
Pen and Paper. Write down 'add footswitch control to patch 15b', so that when you get home you can do it on the pc.
To me, if your rehearsal is about learning music, you should make those changes at home.
But if your rehearsal is about tweaking the show, then you should consider taking EDIT with you so that it is available on the spot.
