ajaykumar Posted June 2, 2015 Share Posted June 2, 2015 I've had my POD HD500x for a few years now and used to use Reaper to record tracks, but recently got a new computer and now use Ableton. However, I get a lot of latency that I can't seem to get rid of. I use Windows 8.1, and Ableton Live Suite 9.1.2 64 bit. My POD has been updated completely. I've messed around in the preferences to no avail (I've attached a screenshot). I can't get the input buffer size to be any lower than 256. I've tried to adjust it to 128 but it just resets. I really don't know what the problem could be. Is it some 32bit/64bit issue? Is it the USB 2.0 cable into a USB 3.0 port? Any help at all would be appreciated. I don't want to go back to Reaper when now I have crazy powerful Ableton. Quote Link to comment Share on other sites More sharing options...
duncann Posted June 2, 2015 Share Posted June 2, 2015 You'll want to select the Line 6 ASIO driver instead of MME/DirectX. And have a look at the Line 6 Audio-MIDI devices control panel for some options about hardware monitoring level, if needed. Quote Link to comment Share on other sites More sharing options...
ajaykumar Posted June 2, 2015 Author Share Posted June 2, 2015 Thanks for your quick reply duncann, that seemed to solve it. The options to adjust input/output buffer sizes are disabled now, but adjusting the driver error compensation now gives me no latency. I had already disabled monitoring through Ableton, but thanks for the suggestion hurghanico. Hopefully someone with a similar problem will find this topic. Quote Link to comment Share on other sites More sharing options...
