scotty_burford Posted June 5, 2015 Share Posted June 5, 2015 Hey guys I have recently started experiencing a lot of noise from the POD HD500 when connecting into my DT25 via Line 6 link. Never experienced this before. It sounds like an earthing issue. The POD then adds all sorts of hiss and crap to the DT. DT by itself sounds as good as ever. Has anyone else experienced this and any ideas on how to fix it? Thanks Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 5, 2015 Share Posted June 5, 2015 Are you using an AES/EBU cable? also make sure that the cable is well seated in the pod and the DT. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted June 5, 2015 Share Posted June 5, 2015 Hey guys I have recently started experiencing a lot of noise from the POD HD500 when connecting into my DT25 via Line 6 link. Never experienced this before. It sounds like an earthing issue. The POD then adds all sorts of hiss and crap to the DT. DT by itself sounds as good as ever. Has anyone else experienced this and any ideas on how to fix it? Thanks I would contact Line 6 through a support ticket or phone. It shouldn't be doing that. Make sure your cable is good. Quote Link to comment Share on other sites More sharing options...
scotty_burford Posted June 7, 2015 Author Share Posted June 7, 2015 Hi Thanks for the repliesYes I have a DMX cable. Cable is good from other testing. I also tried a Planet Waves XLR - same thing.Oh well.... Quote Link to comment Share on other sites More sharing options...
Brazzy Posted June 7, 2015 Share Posted June 7, 2015 Hi Thanks for the replies Yes I have a DMX cable. Cable is good from other testing. I also tried a Planet Waves XLR - same thing. Oh well.... Just in case....are you using a high gain patch and with a noise gate? Just checking 'cause if you don't that might give some noise no matter what in some cases. Quote Link to comment Share on other sites More sharing options...
scotty_burford Posted June 13, 2015 Author Share Posted June 13, 2015 HiNot high gain at all. I'm mainly playing blues and classic rock tunes at the moment, with the amp going from a cleanish just starting to break up to overdrive achieved by running the power amp section up full. Quote Link to comment Share on other sites More sharing options...
Brazzy Posted June 13, 2015 Share Posted June 13, 2015 Hi Not high gain at all. I'm mainly playing blues and classic rock tunes at the moment, with the amp going from a cleanish just starting to break up to overdrive achieved by running the power amp section up full. Hmmmmm, Maybe something's going on with the DT or L6 cable. Quote Link to comment Share on other sites More sharing options...
scotty_burford Posted June 13, 2015 Author Share Posted June 13, 2015 I own a VOX AC15 as well - I have been using that live while trying to figure this out. Hopefully I'll have a couple of days this week and will go through everything from guitars, power sources, leads and the amp to try and nut it out. The rig has been great for almost 4 years now, so hopefully I can get sort it out. Thanks for your help Quote Link to comment Share on other sites More sharing options...
