MrSuit Posted June 6, 2015 Share Posted June 6, 2015 First of all, I have posted the following problem in the Reaper and IK Multimedia forums, but haven't got a real answer. Secondly, My set-up: Me -> Godin Session -> Evidence cable -> Sonic Port VX -> Win7, 64bit, i7, 8GB Ram -> Reaper/standalone programs. The headphones are my AKG K518 and K77. When I'm using my guitar with the sonic port into Amplitube 3 or Pod Farm (either in stand alone or VST) I get a really fizzy sound with overdrive/distortion. Also, in amplitube the difference in volume between clean setting and dirty (especially with an overdrive pedal) is HUGE. In the amplitube manual it says the following: "Tip: if while browsing AmpliTube 3 presets you find that all clean sounds are too quiet and all lead sounds are too high, this means that you’re using a too low input gain on your audio interface.". Now, I can't change the input level, and even after playing with all the input knobs I still get the same results. Has something like this happend to some one else? Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
cptsacksparrow Posted November 5, 2015 Share Posted November 5, 2015 im not sure what the fizzy problem is but i do know that line 6 actually goofed up the coding, when you remove the sonic port it can damage your recording card in your pc and now i have two pcs that cant record because sonic port destroyed the DLL files so the control panel for sound works but as soon as i go to the Recording tab it says not responding and Windows common shell dll not responding, because the port acts as a sounds card. it worked for a session and now reaper wont even open because it cant recognize any sound recording devices on ,my pc. it just says not responding, Line 6 what did u do. :huh: 1 Quote Link to comment Share on other sites More sharing options...
