CreepyMo 0 Posted June 24, 2015 I've noticed a strange issue when controlling my Tweak assigned parameter with the FX button on my Firehawk. What happens is, for reasons unknown, the parameter value range of the knob (all the way to the left to all the way to the right) will change from going between 0-100 to something like 0-xx So far on one stomp box I only got a range from 0-56. On another my range was 0-44. I noticed that when this happens, the white LED on the volume knob does no reflect the actual position that the FX knob is in. So far I have to reboot my Firehawk FX to get the correct 0-100 range back. Is there something I can do to avoid coming across this in the future or is there a fix somehow? Thanks -CM Quote Share this post Link to post Share on other sites
gjhardwick 2 Posted June 24, 2015 Have you checked that the minimum and maximum extents for each stomp box are set correctly in the Firehawk Remote? Quote Share this post Link to post Share on other sites
mcbeddall 109 Posted June 24, 2015 Yeah check that, it would seem some sliders are inched in a bit either end on some of the default settings Quote Share this post Link to post Share on other sites
CreepyMo 0 Posted June 25, 2015 I did...and realized that that was the problem. Thank you! Lots to absorb on this app...I love it. Quote Share this post Link to post Share on other sites
stevekc 185 Posted June 25, 2015 See FX Tweak Assignment indicator example on the far right Quote Share this post Link to post Share on other sites
