molul Posted July 22, 2022 Share Posted July 22, 2022 Here's a proposal for a vocals-oriented HX device: https://line6.ideascale.com/c/idea/1047767/ Quote Link to comment Share on other sites More sharing options...
acousticglue Posted July 28, 2022 Share Posted July 28, 2022 Laney amps, Ampeg guitar amps 1 Quote Link to comment Share on other sites More sharing options...
clfnole123 Posted August 6, 2022 Share Posted August 6, 2022 I think it would be great if there was a way to possibly highlight or bold all the IRs that are currently being used in Presets. This way others could be deleted and replaced without impacting current presets. 1 1 Quote Link to comment Share on other sites More sharing options...
t3chn0babbl3 Posted September 1, 2022 Share Posted September 1, 2022 On 7/29/2022 at 1:33 AM, acousticglue said: Laney amps, Ampeg guitar amps I have been wanting Line 6 to add a model of the Ampeg VH-140C for so damn long. Laney would be interesting, but I find their amps don't have much of a unique voice of their own; they are loud as hell though. I'd choose other amps to add before a Laney and that's with me owning both a VH-140C and a Laney VH100R (among others). For example I'd prefer the Make Dorado, Elmwood Modena 60, Groove Tubes Soul-O (Trio preamp, 30, 75/150, etc), and others. I have two suggestions: Add the ability to interactively trim, cut, copy, and paste audio. For example, with the looper, I'd like to be able to trim it down a loop to exactly what I want; think something along the lines of the Akai MPC. I'd like to be able to import and store (save) in the Helix backing tracks, drum track, and loops I've created with the Helix and be able to assign them to a block in whichever preset or snapshot I want. 1 Quote Link to comment Share on other sites More sharing options...
acousticglue Posted September 15, 2022 Share Posted September 15, 2022 The Helix Edit will not show FULL names when highlighting the dots to be sure of the actual IR. Would like this fixed so can tell last notes on the setting such as will say cap-edge but not enough character for the 2 inch etc 1 Quote Link to comment Share on other sites More sharing options...
acousticglue Posted September 15, 2022 Share Posted September 15, 2022 Would like capacity for more IRs to be loaded Quote Link to comment Share on other sites More sharing options...
acousticglue Posted September 15, 2022 Share Posted September 15, 2022 Would like to have Reverb IR loader with at least mix, EQ high-low rolloff 1 Quote Link to comment Share on other sites More sharing options...
shawnt113 Posted September 17, 2022 Share Posted September 17, 2022 I am not sure if this is the beat place but my wish is for a stand alone pitch pedal from Line 6. I find between my Drop pedal, Pitchfork, Helix Pedals the Helix sounds best. I would love to have a stand alone option. To save CPU on my a helix or fm9 1 Quote Link to comment Share on other sites More sharing options...
acousticglue Posted October 3, 2022 Share Posted October 3, 2022 Less latency on pitch shifting Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted October 3, 2022 Share Posted October 3, 2022 On 10/3/2022 at 2:08 PM, acousticglue said: Less latency on pitch shifting I think if they can figure out a way to do this, they probably will without us asking. Same with reducing DSP. The limits of hardware and modern tech are the key drivers here sadly. Just a tip that you may already know, the "tracking" option controls latency. Lower (X fast) for less latency but lower sound quality. Increase (X Stable) for more latency but better sound quality. 1 Quote Link to comment Share on other sites More sharing options...
fazz1977 Posted October 12, 2022 Share Posted October 12, 2022 No doubt covered already, a mix/blend control on ALL effects (or even just distortions). For example, some of us bassists want to use a RAT/Klon/DS1/Fuzz without destroying our clean low end, and we're already using our parallel route for other things. It would be a really simple addition that would add so much value. 1 Quote Link to comment Share on other sites More sharing options...
showmpiano Posted October 18, 2022 Share Posted October 18, 2022 I'd like to see something based on a Maxon OOD-9 Organic Overdrive, like a Tube Screamer without a tone control for a rhythm boost. Quote Link to comment Share on other sites More sharing options...
iandras Posted October 19, 2022 Share Posted October 19, 2022 I have seen some people suggesting this already, so this post is basically a support for that idea. It would be really useful if there was a noise gate model that used the guitar input as a trigger, and not the actual (and already noisy) output of the preceding block. For example: I put a noise gate after a high gain section (any high gain section, or a block of those), but the gate actually "listens" to my clean guitar signal from the input when deciding when to open. The clean signal is not actually present in the chain, it's just a trigger. It's actually a common way of using gate pedals (Boss N2-2, TC Sentry, Decimator G string, ...these all have the feature of using fx in a loop, while taking the detector input form the clean instrument). It's much clenaer and more precise gating that using a gate in series after the high gain section. I'd be delighted to see this feature in a future HX update. Quote Link to comment Share on other sites More sharing options...
datacommando Posted October 20, 2022 Share Posted October 20, 2022 On 10/19/2022 at 12:45 PM, iandras said: I have seen some people suggesting this already, so this post is basically a support for that idea. Hi, If you wish to support a suggestion you need to “upvote” that idea on the IdeaScale website. Posting in this thread is basically to let others know about the idea, and point them to where they can vote for it. Line 6 staff don’t monitor these forums, and therefore your comment will have little or no chance of anyone from Line 6 seeing it and getting it implemented. Has this idea actually been submitted on IdeaScale? https://line6.ideascale.com/c/campaigns/51424/stage/all/ideas/unspecified You didn’t mention if you have done that on IdeaScale. BTW, you need to be registered and logged in to vote. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
ossianott Posted October 20, 2022 Share Posted October 20, 2022 Dual mono global EQ would be nice, lets say you rely on one device (helix, helix LT or stomp) for two guitarrists running thru one 4x12 cabinet each, being able to individually tweak each 4x12 depending on venue/location with global eq would be awesome me thinks! 1 Quote Link to comment Share on other sites More sharing options...
darkstrings440 Posted November 6, 2022 Share Posted November 6, 2022 The Ampeg VH140C in the next wave of modeled amps would be awesome. Been waiting for that for years. 1 Quote Link to comment Share on other sites More sharing options...
aostler Posted November 8, 2022 Share Posted November 8, 2022 I just put these two up on IdeaScale: 'Kill Dry' or dry level control for Looper https://line6.ideascale.com/c/idea/1054072 Different curves for Split A/B https://line6.ideascale.com/c/idea/1054073 Quote Link to comment Share on other sites More sharing options...
XONE Posted November 9, 2022 Share Posted November 9, 2022 I'm really desperate for two Legacy models to be included in a future Helix update: 1. The Sub Dub Bass model: This is the best Bass model you ever made, and was the basis of my tone in my Bass POD XT Pro. Great model for a super modern Bass tone 2. The Hi-Talk pedal model. The particular algorithm of this pedal is excellent. I used this effect a lot in my Vetta HD, and I miss it a lot, It's part of the signature sound of my band's biggest song. Really need this. Thanks for all your awesome hard work! Quote Link to comment Share on other sites More sharing options...
datacommando Posted November 9, 2022 Share Posted November 9, 2022 On 11/9/2022 at 7:52 PM, XONE said: I'm really desperate for two Legacy models to be included in a future Helix update: 1. The Sub Dub Bass model: This is the best Bass model you ever made, and was the basis of my tone in my Bass POD XT Pro. Great model for a super modern Bass tone 2. The Hi-Talk pedal model. The particular algorithm of this pedal is excellent. I used this effect a lot in my Vetta HD, and I miss it a lot, It's part of the signature sound of my band's biggest song. Really need this. Thanks for all your awesome hard work! Hi, There are no Line staff here and only very occasionally do they visit these forums - See the “sticky comment” in the black banner stripe at the top of this page entitled “Welcome to the Line 6 forums” This link is where you need to go to have any hope of it been seen by anyone from Line 6: https://line6.ideascale.com/a/index Before posting any new ideas, please do a search to see if it's already been listed. Multiple requests for the same thing will thin out the votes. Also, post your ideas one at a time. Many users don’t vote for combined suggestions. You should use this thread to let other users know what your suggestions are, with links to IdeaScale, so they can vote on it if they wish. https://line6.com/support/topic/14497-helix-ideascale-community-submissions/ Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
LadyKitty Posted November 11, 2022 Share Posted November 11, 2022 As someone who uses midi control panels a lot for settings, I noticed some things lacking access to Midi CC in IR and Cab blocks while they could be really useful for dialing guitar sound (Though otherwise pretty much all other values in Helix are midi-controllable so guess it might be an oversight?): -IR: IR Select (doable by each value in the control responding to an IR, like CC33 value 63 would correspond to 64th IR) -Cab: Mic (Since there's 12 mics, there's 10.666 values per mic so spreading the mic values for 10-11 values per mic would work) -Cab: Position -Cab: Distance (Midi CC-able in Legacy cabs but not in new ones) -Cab: Angle (0-63: Normal, 64-127: 45 degrees) Quote Link to comment Share on other sites More sharing options...
zappazapper Posted November 12, 2022 Share Posted November 12, 2022 On 11/10/2022 at 10:14 PM, LadyKitty said: -Cab: Distance (Midi CC-able in Legacy cabs but not in new ones) Sorry but I'm not seeing the ability to assign a MIDI CC to the Distance parameter on the Legacy cabs. And I'm personally struggling to think of a useful application for controlling the mic distance with a switch or MIDI control, but just because it's not something I would do, doesn't mean I don't think every parameter of every block should be available to be controlled via an onboard controller or MIDI, so I'm with you on that. On the other hand, this is the first time I've noticed anyone point out the lack of MIDI access for cab parameters, so I don't know how much support from the community you'll get, which is part of what gets things like this done in upcoming updates. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted November 12, 2022 Share Posted November 12, 2022 On 11/12/2022 at 2:40 AM, zappazapper said: the lack of MIDI access for cab parameters This is obviously "by design" for this new feature. From the HX Edit 3.50 Pilot's Guide: Quote Mic † Distance † Position † Angle † […] †NOTE: These parameters are not available for Expression Pedal, Variax Knob, or MIDI CC Controller assignment. Quote Link to comment Share on other sites More sharing options...
zappazapper Posted November 12, 2022 Share Posted November 12, 2022 Auto Impedance setting for Loop block https://line6.ideascale.com/c/idea/1054260 Quote Link to comment Share on other sites More sharing options...
zappazapper Posted November 12, 2022 Share Posted November 12, 2022 On 11/12/2022 at 7:00 AM, lou-kash said: This is obviously "by design" for this new feature. Fair enough. Quote Link to comment Share on other sites More sharing options...
WLTSCHMRZ Posted November 13, 2022 Share Posted November 13, 2022 Loving this new update, but I do hope the the next update will add more cabs. My favorite (the HiWatt one) wasn't among the remastered cabs and I'm salivating at the idea of how good it could sound with the new cab engine. Quote Link to comment Share on other sites More sharing options...
JimGordon Posted November 13, 2022 Share Posted November 13, 2022 Please add the 112 Dynamic Mic (AKG) into the new guitar cabs section; the top end on those is useful if you want more high end presence "grind". Also, as someone else said, a new WhoWatt cab model would be great. Quote Link to comment Share on other sites More sharing options...
zappazapper Posted November 14, 2022 Share Posted November 14, 2022 "Lose the 8 Snapshot limit": https://line6.ideascale.com/c/idea/1054276 "Expand per-Snapshot assignments": https://line6.ideascale.com/c/idea/1054308 "Allow Input and Output block assignments to be controlled": https://line6.ideascale.com/c/idea/1054310 Quote Link to comment Share on other sites More sharing options...
martinstender Posted November 21, 2022 Share Posted November 21, 2022 I'd like to raise attention to this idea (https://line6.ideascale.com/c/idea/942459) - It would be very practical to be able to restore a snapshot to its saved state, if snapshots are set to recall. Because sometimes you alter a bunch of stuff on the fly, and it could be great to be able to reset a snotshot to its saved state. This could be done in a few ways... maybe by pressing-and-holding the snapshot switch for 2 seconds or - maybe better - tap the snapshot switch twice within two seconds. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 21, 2022 Share Posted November 21, 2022 On 11/21/2022 at 6:47 AM, martinstender said: I'd like to raise attention to this idea (https://line6.ideascale.com/c/idea/942459) - It would be very practical to be able to restore a snapshot to its saved state, if snapshots are set to recall. Because sometimes you alter a bunch of stuff on the fly, and it could be great to be able to reset a snotshot to its saved state. This could be done in a few ways... maybe by pressing-and-holding the snapshot switch for 2 seconds or - maybe better - tap the snapshot switch twice within two seconds. You can already do this easily for all snapshots with two foot taps. Select a different preset and then return to the current preset. It will be reloaded in its saved state, including all snapshots. Or do you want this capability for a single snapshot? 1 Quote Link to comment Share on other sites More sharing options...
Dmac8684 Posted December 8, 2022 Share Posted December 8, 2022 Combined Delay+Reverb Block I am coming from the HX Stomp. With the changes in 3.5 freeing up DSP from cabs and IR's, there is some opportunity for more flexibility in the unit. I think it would be an immense update to add a Delay+Reverb block that functions like the Amp+Cab block. Click the Delay+Reverb setting, and the HX Delays pop up, then you can toggle over to reverbs in the same manner that you can toggle over to cabs in the Amp+Cab setting. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted December 9, 2022 Share Posted December 9, 2022 On 10/19/2022 at 4:45 AM, iandras said: I have seen some people suggesting this already, so this post is basically a support for that idea. It would be really useful if there was a noise gate model that used the guitar input as a trigger, and not the actual (and already noisy) output of the preceding block. For example: I put a noise gate after a high gain section (any high gain section, or a block of those), but the gate actually "listens" to my clean guitar signal from the input when deciding when to open. The clean signal is not actually present in the chain, it's just a trigger. It's actually a common way of using gate pedals (Boss N2-2, TC Sentry, Decimator G string, ...these all have the feature of using fx in a loop, while taking the detector input form the clean instrument). It's much clenaer and more precise gating that using a gate in series after the high gain section. I'd be delighted to see this feature in a future HX update. Are you aware of the noise gate at the input of the HX Stomp? See page 22 of the manual. It's always there. Or are you talking about the HX Effects? I do not have one. If you're talking about that, so if you put a noise gate at the beginning, it only stops the audio there at that block? It doen't "mute" everything? if it doesn't, your' only solution is to have two gates. One at the input and one after all the noisy stuff. Quote Link to comment Share on other sites More sharing options...
thebeeze111 Posted December 14, 2022 Share Posted December 14, 2022 Not sure if this is the place for this, but I tried registering on ideascale and have been waiting for the confirmation email since yesterday. Checked spam also. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
PabloStereo Posted December 21, 2022 Share Posted December 21, 2022 How about a MUTE option next to the Bypass and Delete icons on top of the Blocks. When I am profiling 2 amps in parallel lanes it's very important I could totally mute one of them while I dial in the other one.. Thanks. Quote Link to comment Share on other sites More sharing options...
dbudday Posted December 30, 2022 Share Posted December 30, 2022 I had an idea for acoustic guitars that I think a lot of players would love. I know that there are quite a few players that run acoustic guitars through their Helix...with tremendous results. I am imagining a block in HX edit - maybe even a separate Helix - for acoustics - that models acoustics like amps. You could choose different body types or models of acoustics - and they would all be modeled. You could even adjust the mics like you would at the neck and soundhole - much like the speakers and mics in the amp models. Just like the amps are studied and modeled - different models of acoustics could be done the same way and then those models made available in an "acoustic designer" block. I figure - this way you can pick your acoustic model - then add any effects - and use the acoustic model/block in place of amps when you have an acoustic plugged in. 1 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted December 30, 2022 Share Posted December 30, 2022 On 12/29/2022 at 11:13 PM, dbudday said: I had an idea for acoustic guitars that I think a lot of players would love. I know that there are quite a few players that run acoustic guitars through their Helix...with tremendous results. I am imagining a block in HX edit - maybe even a separate Helix - for acoustics - that models acoustics like amps. You could choose different body types or models of acoustics - and they would all be modeled. You could even adjust the mics like you would at the neck and soundhole - much like the speakers and mics in the amp models. Just like the amps are studied and modeled - different models of acoustics could be done the same way and then those models made available in an "acoustic designer" block. I figure - this way you can pick your acoustic model - then add any effects - and use the acoustic model/block in place of amps when you have an acoustic plugged in. This is very Variax-like. And I'd love something like this. I do something like it with IR now, but to have some already set, like the new built-in cabinets, would be wonderful. 1 Quote Link to comment Share on other sites More sharing options...
brettyc Posted January 11, 2023 Share Posted January 11, 2023 Command Center in HX Edit, a drop down list of pedal + manufacturer + function. Then Command Center knows the parameter info required to accomplish that function. This way, we don't have to go find a manual and look up values every time we want to assign a parameter. Quote Link to comment Share on other sites More sharing options...
acousticglue Posted January 11, 2023 Share Posted January 11, 2023 2 pole-4 pole filter along with widening, left right shift for tone(panning) and midside settings. 4 pole and drive can be really nice together with this shifting used Quote Link to comment Share on other sites More sharing options...
rusberti Posted January 15, 2023 Share Posted January 15, 2023 Hi I would like to propose a new custom type of output for Helix where the user can select any combination of outputs between all of the physical ones (checkbox style), how can I enlist this idea? Custom Output: Digital Out and/or XLR and/or USB 1/2 and/or USB 3/4 and/or XLR, etc.. Quote Link to comment Share on other sites More sharing options...
movingmatter Posted January 16, 2023 Share Posted January 16, 2023 On 11/25/2021 at 9:34 PM, bgrizzmayne said: I want a second page of stomps. if i have 15 effects in a preset, why am i limited to 10 foot switches? give us the option to add a second page with the additional foot switches for on the fly control over every part of a preset. im using my helix 4cm with an amp and would love to not be limited to just 10 stomps A second page of stomps would be amazing! Jamband musician here, and sometimes the moment calls for a certain effect that I don't use too often. 1 Quote Link to comment Share on other sites More sharing options...
clfnole123 Posted January 17, 2023 Share Posted January 17, 2023 Channel 2 (Crunch) of the Diezel VH4 (Das Benzin). Quote Link to comment Share on other sites More sharing options...
