malnack Posted July 8, 2015 Share Posted July 8, 2015 When I was using my HD500 the other day, it no longer showed the new amps from the amp pack. I launched Line6 Monkey and it said that my HD500 was not authorized. After a bit of troubleshooting I decided to reboot my whole system (rebooting the HD500 did not correct it). When my PC was rebooted, the new amps were available again:) At the time I encountered the issue, I had the HD500 on one USB port, my AudioBox 1818 VSL connected to another. I was using HD Edit while I was recording tracks in Studio One v3. At some point I disconnected the HD500 and plugged in my Axiom keyboard controller to add a keyboard part. It was after I was done doing that and plugged the HD500 back in that the problem appeared. So, Studio One must've held onto the USB port a bit. 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted July 8, 2015 Share Posted July 8, 2015 Reboot the computer. It solves 90% of problems. And if you reboot regularly, it prevents 95% of the problems from happening. Quote Link to comment Share on other sites More sharing options...
titchyblackcat Posted July 10, 2015 Share Posted July 10, 2015 A bit late i know but, i've had this sort of thing with the USB. I use an Axiom, Pod HD and run Cubase and Reason I have to start the software in the correct sequence for it to run OK. Quote Link to comment Share on other sites More sharing options...
