mattbarden
Good amp to run 4cm Hi-Gain
Who has had good success with running an amp that has a good hi-gain channel in the 4CM method and what amp was it? I'm in the market for an amp to produce good stage volume and air movement. I know FRFR's are recommended but even with decent FRFR's it's just isn't cutting it for me. Back in the day I used to use a crappy Crate amp but even that moved more air behind me than the FRFR's do and I kind of need that to get into my groove. I'm interested in the DT's but I'm all about try before you buy and nobody ever has them in stock in my area. Looking for some alternative solutions based on real life experience if you could. Money isn't TOO big of an issue but 2-3k or less for the full package (amp and cab) would be sweet. For reference my Hi-gains are something akin to 90's Metallica and Alice in Chains type of sounds. Thanks in advance!
I guess I should say that I don't do too overly much for clean sounds but it does pose a factor into my setlist so this is also kind of needed but I'm not too picky about the cleans as long as they're decent enough. I'd be using my POD 500X as an FX only unit for live situations, but still using it to track ideas at home with the amp sims as that is decent enough. I just find that the digital is a bit lacking on stage/jam sessions with other musicians vs analog, at least for me anyways. I can tap dance around an amp's channel switcher and the POD to get my results so that isn't an issue.
4CM works great with my Mesa amps - Stiletto, Rectoverb 25, Mark V:25. You should be good with any amp with a quality buffered series fx loop. I added a Voodoo Lab Control Switcher so that I can change amp channel via midi from the HD500.
Excellent, I was leaning towards a dual or tri rec so it's good to know it works well with Mesa stuff.
Note that the older rectifier amps have parallel fx loops (mine did at least), so you'd need to do a serial loop mod for those.
I'm using my HD500 with a Randall RM100 and it works great once you have the Pod set up right. At first I was unhappy because it was a serious tone sucker. After some research I got it worked out and sounds great. The amp has midi so I use the Pod to change channels too.
Yeah the tone sucking thing was one of my concerns. What sort of tweaks did you have to do to overcome it?
Set your patch input z to 1M or 3.5M. Place the fx loop after the mixer on the Pod. Pan channel A & B to center and then turn them both up from 0 to +3 dB on both. I was getting ready to get rid of the pod until I this tip on a Blackstar forum.
  • Upvote 2
