Sign in to follow this
shagtones
wah volume
Just a guess, but one possibility could be that you have a volume pedal and wah assigned to the same EXP, of which there are two. I'm also guessing when you say volume increase, this happens when the pedal is more towards the toe position?
it also depends on if you are having a volume increase or a perceived volume increase.
A lot of people will engage the Wah for solos because of the eq change. No real volume change, but it changes the tone in certain frequencies to make you think it is the volume.
check your input settings guitar - same or other.
using a mono effect before the split can make the difference of feeding a signal to path b or not
