expression pedal taper rate
timthompson
I am having a problem with sensitivity of my volume pedal.  The first 30 percent of my volume pedal hardly making much volume change, and most of the volume coming in at 70 - 100 pecent. any Idea how to change taper rate? also my expresion pedal is too easy to push.
Another possible solution, that might or might not fit your needs is to use it as a control pedal on the master volume of the amp instead of as a volume pedal. You will get your audio taper that way. You may need to also control the drive, to get a similar effect as that achieved with a vol pedal before the amp. You could also try it on a compressor's volume.
I almost never use it as a volume pedal, but instead as I suggested above.
