timthompson Posted July 27, 2015 Share Posted July 27, 2015 I am having a problem with sensitivity of my volume pedal. The first 30 percent of my volume pedal hardly making much volume change, and most of the volume coming in at 70 - 100 pecent. any Idea how to change taper rate? also my expresion pedal is too easy to push. Quote Link to comment Share on other sites More sharing options...
duncann Posted July 27, 2015 Share Posted July 27, 2015 You could try doing a pedal calibration. That might fix the odd volume behavior you describe. Can't change the taper, unfortunately. To fix the tension, tighten the allen bolt a little. It's on the outside edge on the pedal's axis of movement. Quote Link to comment Share on other sites More sharing options...
timthompson Posted July 29, 2015 Author Share Posted July 29, 2015 Thanks Guys, I appreciate your input. I will try your suggestions. Thanks Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted July 30, 2015 Share Posted July 30, 2015 Another possible solution, that might or might not fit your needs is to use it as a control pedal on the master volume of the amp instead of as a volume pedal. You will get your audio taper that way. You may need to also control the drive, to get a similar effect as that achieved with a vol pedal before the amp. You could also try it on a compressor's volume. I almost never use it as a volume pedal, but instead as I suggested above. Quote Link to comment Share on other sites More sharing options...
