If I had all the guts for a JTV 69, is it possible to connect the "model selector knob" from a JTV-59 to that circuit board?
Also, does anyone have pictures of what it looks like under the pick guard of the JTV-69?
The device under the knob is the same, so the Models will come
up in the same order, in the same way.
However, the stop points on either end are such, that the Model labels
on the knob won't line-up perfectly with the select LED indicator (just tried
it on one of my test fixtures). So, there may be some confusion which Model
is engaged until you play it (or it come up on the display of your multi effects
floor unit, if you have one).
Aside from those caveats, should work fine.
