stevetron3030 0 Posted August 5, 2015 Sorry if this has been discussed in previous threads, but I can't recreate the spacious of listening directly to my tone from the headphone out. I have my pod set to Studio Direct Out, the board itself is set to line and not amp, and my 1/4' cables work great. Despite that I'm not hearing depth in my delays or movement in my reverbs. I also don't have any mono summing effects in my chain. I do have two h9's in my effects loop and pursued this setup with stereo effects in mind. Am I missing something basic? Quote Share this post Link to post Share on other sites
phil_m 4,517 Posted August 5, 2015 What are you connected to? A mixer? If so, are the channels on the mixer panned correctly? Quote Share this post Link to post Share on other sites
Leftzilla 125 Posted August 5, 2015 Thats the first thing i would check also. Failing that I would run a stereo Y from the headphone out to the mixer. Quote Share this post Link to post Share on other sites
pianoguyy 412 Posted August 5, 2015 Assuming you are using stereo headphones direct from the pod... Did you check the mixer settings? I mean the mixer within the patch, not the external mixing board. You can find left/right and volumes there. I don't use the fx loop, so I don't know how it works. But I wonder if where you have the fx loop positioned in the chain may have a mono-summing result? Quote Share this post Link to post Share on other sites
stevetron3030 0 Posted August 7, 2015 Thanks for the responses. I've been running direct into my interface. I'll try these out tonight! I haven't had access to a pa, I'll report back. Quote Share this post Link to post Share on other sites
