Abitbol Posted August 6, 2015 Share Posted August 6, 2015 Hello, As i have updated to Windows 10, my guitarport is not able to play sound files (via any software like WMP, vlc, ...). I have updated to last drivers. (The guitar sound via Podfarm still work.) Thank you Quote Link to comment Share on other sites More sharing options...
Abitbol Posted August 6, 2015 Author Share Posted August 6, 2015 Finaly I have the solution. In the Guitarport Advanced properties, I select DVD quality 16 bits, 48000Hz (44000Hz before), and it works. 1 Quote Link to comment Share on other sites More sharing options...
steelman63 Posted August 6, 2015 Share Posted August 6, 2015 Thanks for the tip. Worked a treat! Quote Link to comment Share on other sites More sharing options...
swoolford Posted August 7, 2015 Share Posted August 7, 2015 Thanks! You've saved me a lot of time, the same thing worked for me! Quote Link to comment Share on other sites More sharing options...
chaztrip Posted August 8, 2015 Share Posted August 8, 2015 You Rock!!!!!!!!! Fixed me up as well thanks!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
maidenas Posted August 9, 2015 Share Posted August 9, 2015 Thanx mate, you saved my day!!!! Quote Link to comment Share on other sites More sharing options...
mlipping Posted August 10, 2015 Share Posted August 10, 2015 It seems to be the fix. I'm thinking that a new driver update is coming soon as this seems to be a problem with a lot of Line6 products. M Quote Link to comment Share on other sites More sharing options...
geeman37 Posted August 10, 2015 Share Posted August 10, 2015 im using guitar port and gearbox but i cant get any songs to play. the guitar sounds work but i can not find the options you say can anyone plaease help. many thanks Quote Link to comment Share on other sites More sharing options...
Abitbol Posted August 20, 2015 Author Share Posted August 20, 2015 I'm happy to see this trick works for most of you ! geeman37, as the Line6 Team said, try this : "As a potential workaround, some users have noticed that setting the Windows sample rate to 48000 Hz resolves the issue. Go to Control Panel, click on "Sound", click on your Line 6 device, click the "Properties" tab, then click on the "Advanced" tab. In the "Default Format" section, there's a drop down menu which gives you a list of sampling frequencies" 1 Quote Link to comment Share on other sites More sharing options...
geeman37 Posted August 26, 2015 Share Posted August 26, 2015 thank you I will give this a try and keep you informed. Quote Link to comment Share on other sites More sharing options...
