Pubba50 Posted August 20, 2015 Share Posted August 20, 2015 Heya guys! :) I just got my HD500 today and am loving it so far! I hook up straight to the mixer-no issues there. It must be a preset thing but when I start to play the volume increases for 1 second. Say i'm doing a bend to start, it sounds quiet then it goes to normal volume in a second. Like a delayed sound. It sounds annoying any ideas what this could be? Im thinking maybe a compressor or noise gate thing. Cheers! :) I'm using the "left mono inbalanced output" with a lead to the mixer. Sound is great but it sounds like a settings or connection issue if it's not meant to be. Quote Link to comment Share on other sites More sharing options...
Pubba50 Posted August 20, 2015 Author Share Posted August 20, 2015 Lol now I have no sound at all😞 Quote Link to comment Share on other sites More sharing options...
napynap Posted August 20, 2015 Share Posted August 20, 2015 It would help to add more details, like which outputs you are using, whether it happens when connecting to an amp, or using headphones, different guitar, etc... Quote Link to comment Share on other sites More sharing options...
Pubba50 Posted August 20, 2015 Author Share Posted August 20, 2015 It would help to add more details, like which outputs you are using, whether it happens when connecting to an amp, or using headphones, different guitar, etc... Ok thanks-don't have the liberties of an amp alternative but I can try another guitar and headphones. Thanks Quote Link to comment Share on other sites More sharing options...
Pubba50 Posted August 20, 2015 Author Share Posted August 20, 2015 Nah no luck-should I try the XLR output instead of the unbalanced? Quote Link to comment Share on other sites More sharing options...
spawn2031 Posted August 20, 2015 Share Posted August 20, 2015 You can certainly give that a shot, the XLR outputs are quieter than the unbalanced ones but unless you have something freaky going on with the preset it sounds like you have a bad unit. Have you tried using a completely blank patch? Quote Link to comment Share on other sites More sharing options...
Pubba50 Posted August 20, 2015 Author Share Posted August 20, 2015 Hmmm yeah. Still have to try XLR outputs. I've tried a blank patch yeah same thing. I actually noticed lastnight it seems a signal issue. When i'm already playing it doesn't happen. When I first hit the strings there's definitely a split second of sound lag as it picks up the signal. I bought it 2nd hand-the guy seemed pretty genuine so i wouldn't propose he knew about it. Probably didn't notice. It's quite frustrating. It's just slow to pick up the first signal of sound. May just ring Line 6 about it. Cheers mate. Quote Link to comment Share on other sites More sharing options...
napynap Posted August 22, 2015 Share Posted August 22, 2015 I think the next step is to check for latest firmware and update with Line6 Monkey, (unless it's just an intermittent bad guitar cable?). Quote Link to comment Share on other sites More sharing options...
