cocia 0 Posted August 23, 2015 I would like to know if there is a way with the pedal HD500, to overlay and mix the clean guitar signal to the effects ........ for example, I would like my final sound is a clean sound + sound distorted not only a clean sound or only a distorted sound, and i wish they were the two mixed sounds ....... You 'can do everything with HD500? or do I have to buy a blend mix ???? What if you could do that with HD500, send procedure ...... thank you Francis Quote Share this post Link to post Share on other sites
pianoguyy 414 Posted August 23, 2015 There is no 'mix' feature, per se. But you can run a split signal - where the left is your fx and the right is clean. And then you have various options to mix and switch. Whether it be panning between left and right or volume up/down. That would be up to you decide. Quote Share this post Link to post Share on other sites
