Jacksc5 Posted August 23, 2015 Share Posted August 23, 2015 When using 4 cable method with no amp sim i find that it sounds like the amp is being driven slightly. If I disconnect the firehawk and plug straight into the amp it's crystal cleans again. What am I doing wrong?? I'm using H&K Tubemeister 18 Quote Link to comment Share on other sites More sharing options...
oddbeck Posted October 16, 2015 Share Posted October 16, 2015 Did you figure this one out? Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted October 16, 2015 Author Share Posted October 16, 2015 Yes. I gave up sold it and went back to pedals. LOL I've finally come to the conclusion that buying something that is okay at lots of things is not as good as buying something that is great at one thing. Sticking with pedals from now on. Much happier even if I do have less ££ in my pocket and not as many effects. Cheers :) Quote Link to comment Share on other sites More sharing options...
oddbeck Posted October 16, 2015 Share Posted October 16, 2015 I see. Did you use the preamp on your amp ? The clue to having 4cable method working, as far as I've figured out at least, is to disable amp modeling in the setting of the patch. Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted October 16, 2015 Author Share Posted October 16, 2015 Hi yes I tried disabling the amp models and using them. Couldn't get it to sound right. I was probably my short patience rather than Line 6 failings but much happier with pedals again. Only problem is GAS, keep buying pedals... Quote Link to comment Share on other sites More sharing options...
oddbeck Posted October 16, 2015 Share Posted October 16, 2015 Yeah, GAS is a common problem... ah well, things could be worse :) Quote Link to comment Share on other sites More sharing options...
