Jacksc5
Muddied sound with 4 cable method
When using 4 cable method with no amp sim i find that it sounds like the amp is being driven slightly. If I disconnect the firehawk and plug straight into the amp it's crystal cleans again.
What am I doing wrong??
I'm using H&K Tubemeister 18
Yes.  I gave up sold it and went back to pedals.  LOL
I've finally come to the conclusion that buying something that is okay at lots of things is not as good as buying something that is great at one thing.  Sticking with pedals from now on.  Much happier even if I do have less ££ in my pocket and not as many effects.
Cheers :)
I see. Did you use the preamp on your amp ? The clue to having 4cable method working, as far as I've figured out at least, is to disable amp modeling in the setting of the patch.
Hi yes I tried disabling the amp models and using them. Couldn't get it to sound right. I was probably my short patience rather than Line 6 failings but much happier with pedals again. Only problem is GAS, keep buying pedals...
Create an account
Register a new account
Sign in
Sign In Now
