bobsbro Posted August 30, 2015 Share Posted August 30, 2015 Hey guys. Had my last practice with my hd400 yesterday. Getting the hd500x on Wednesday. I plan on creating several stereo patches. But there's a few things I'd like to prempt. 1. If I split a channel to two separate amps, and then merge back and put effects after the split. Will it still be stereo. Or will it be mixed back down to mono. 2. How do you connect it to a pa that doesn't have a pan on each channel. It does have rca connection. Can I use an rca connector at the end of my guitar cables? Or would they operate at different levels? (Are they all line level) 3. What cheap cases can fit the pod and cables? Quote Link to comment Share on other sites More sharing options...
CipherHost Posted August 30, 2015 Share Posted August 30, 2015 1. The amps are mono, but if you place a stereo effect after them you will have stereo out. 2. If the PA has no pan, it probably is not a stereo PA. I was a little surprised when I first saw one. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 30, 2015 Share Posted August 30, 2015 2. If it doesn't have a pan - I hope you tested your patches so that your delays don't don't double up and sound like lollipop when mono. The XLR and 1/4" are different levels. If you feel safe using an rca adapter, then there is no reason why you can't use it. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted August 31, 2015 Share Posted August 31, 2015 Question #3) Google "HD500 case" and you'll find all sorts of cases/bags suitable for the HD500 and cables. Quote Link to comment Share on other sites More sharing options...
CipherHost Posted August 31, 2015 Share Posted August 31, 2015 somewhere in this site there is a downloadable doc listing all the mono, stereo, true stereo, etc. FXs Quote Link to comment Share on other sites More sharing options...
jandrio Posted September 1, 2015 Share Posted September 1, 2015 from L6 knowledge base Stereo/Mono FX List for POD HD Quote Link to comment Share on other sites More sharing options...
