Bass HD Model Pack - can't see the amps
kmsh
Sorry if the question is a noob one.
I've purchased the HD fully loaded pack (metal, vintage & bass).
I can't see the Ampeg & GK Amps in my HD500x neither in the editor. I assume they have different names but can't find out wich ones ?
Does someone has a mapping table for this ?
Or maybe the models haven't been implemented correctly during the install procedure.
I will use an active Ibanez, a 5 chords peavey and a jazz bass fretless on it  BTW.
Thanks for you help/advices
Best regards.
K.
If you're not seeing the new amps just the edit software, make sure to install the latest version, 2.26. If they also don't show up on the device, did you run the license manager to authorize your device?
These are the names that should appear in HD Edit and the device
--Metal Pack Amp Models--
PV Panama
Mahadeva
Brit 2204
Octone
Insane
Big Bottom
Variac'ed Plexi
Purge
Aggro
Smash
--Vintage Pack Amp Models--
Small Tweed
Jazz Rivet
Mandarin 80
A30 Fawn Brt
A30 Fawn Nrm
Black Panel Pete
Acoustic
--Bass Pack Amp Models--
SVT Brt
SVT Nrm
G Cougar 800
And the cab models:
--Vintage Pack Cab Models--
1x8 Champ
212 Jazz Rivet
--Bass Pack Cab Models--
810 SV Beast
410 Rhino
Acoustic
SVT Brt
SVT Nrm
G Cougar 800
810 SV Beast
410 Rhino
Thanks a lot Duncan, that's what I was looking for. I had them, but was not able to map those names to GK or Ampeg :(
Maybe this is something that line6 has somewhere.
Once again, thanks for your help/ :)
Cheers.
