Sign in to follow this
donnyedge
HD500x
As I understand it, it's called a "Global EQ" because it applies to ALL presets. ON for all or OFF for all. It's intended use is to accommodate differences in room acoustics that you might encounter from night to night, or even differences in crowd size on a given night.
@rd2rk
I think he is talking about changing the default values when you are using the Pod, not EDIT.
@donnyedge
No, you can't change the default values. But they are better than trying it on EDIT where everything is zeroed out.
@pianoguyy
AH! He's referring to the defaults that Line6 hard-coded as initial settings when an amp is first inserted into a preset.
@donniyedge
Pianoguyy is right, they can't be changed and, unlike many computer amp sims, you can't save a "Settings" file. BUT... you could create a blank preset template with the amp/cab settings you like, and use that as a starting point when you create presets using that amp....Are either of us understanding what you're asking here?
