Atomant669 Posted September 13, 2015 Share Posted September 13, 2015 Help, i have gotten my POD HD 500X for almost a year now but it seems that I can never seen to assign the wah to the foot controller through EDIT software. I'm sorry to say the the manual isn't very helpful and rather confusing. Whenever I try to assign the wah to FS8. The light doesn't come on. and it seems that only FS1 and FS2 is on all the time which has been assigned to Noise Gate and Screamer. I know I must be missing something. Someone please help? Quote Link to comment Share on other sites More sharing options...
Atomant669 Posted September 13, 2015 Author Share Posted September 13, 2015 The footswitches seems to be switching between presets than turning the wah on or off. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 13, 2015 Share Posted September 13, 2015 for starters you are in 1-4 mode instead of 1-8 mode. 1-4 for fx. 4-8 for presets. VS 1-8 for fx. Pedalboard Mode vs ABCD page 14 of the Pilot's Guide Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 13, 2015 Share Posted September 13, 2015 Next up ---- Using EDIT goto the Controllers tab. That is where you assign footswitches. Question - Why are you trying to assign a wah to an on/off switch instead of the exp pedal? There are reasons why one would do this, but I am curious if yours is one of them. Quote Link to comment Share on other sites More sharing options...
Atomant669 Posted September 14, 2015 Author Share Posted September 14, 2015 Oh thanks a lot pianoguy. I have found the answers in the pilot's manual. And to answer your question as to why assign a wah to an on/off switch instead of the exp pedal I have no clue at all. Can you even assign an on/off switch using the EXP pedal? All I know is that you can switch between exp1 and exp2 with the expression pedal. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 14, 2015 Share Posted September 14, 2015 When you switch from pedal 1 to 2, it is the same as turning it on and off. So, if you have the wah on exp2, when you have on exp 1, the wah is off. Changing to exp2 would turn it on. One of the reasons someone may use a footswitch instead of the exp pedal would be --- let's say you didn't want to chic-chica-chicah, but you wanted to use the effect as an eq at a certain frequency. you assign the value and then on/off it. Which works nicer than trying to kick on exp2 and then find that perfect frequency. Quote Link to comment Share on other sites More sharing options...
Atomant669 Posted September 15, 2015 Author Share Posted September 15, 2015 Great, now I have found another use for the wah pedal. Thanks pianoguy for the kickstart. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted September 15, 2015 Share Posted September 15, 2015 The exp pedal can do anything. I have a couple patches where I can increase the amount of gain. Instead of having a clean and dirty sound, I have all points in between. Real-time pitch shifting. Volume control, I think is a no brainer. But instead of using a separate block as a volume pedal you assign the exp pedal to the amp volume. Panning. Not just left and right. But panning between your clean and dirty amps. If the Pod can do it. The exp pedal can control it. AND, what is different about the exp pedal is that it can control numerous things at the same time. I have one where the pitch goes up while the volume goes down. Quote Link to comment Share on other sites More sharing options...
napynap Posted September 16, 2015 Share Posted September 16, 2015 ...Volume control, I think is a no brainer. But instead of using a separate block as a volume pedal you assign the exp pedal to the amp volume. Panning. Not just left and right. But panning between your clean and dirty amps. I want to start using the Exp pedal as you describe for changing between clean/dirty, or adding delay feedback, etc.. but I disable it's volume control because too many things happen on our stage that can catch the pedal and make it go to zero, which always sounds bad. Quote Link to comment Share on other sites More sharing options...
