Which Amps ?
titchyblackcat
Either Soldano Crunch or Overdrive would be good. There's a lot of amps in there, though, that cover a middle ground. You could also use a clean amp and add some overdrive in front of it, which might provide a little more flexibility within a single patch.
As another option for clean, there's also Soldano Clean.
Fenders for clean. Marshalls for grind. Phd Motorway for blues and country. That's about it but there is usually a good bit of tweaking with the cabs going on. I also tend to not use the overdrive or distortion boxes. I use the drive knob and the master volume to drive the amp sim in to distortion just like you would a real amp. Also a little compression to even things after the amp. I like compression after the amp because the amp reacts to my volume changes on my guitar very much like the real thing.
  • Upvote 2
Thanks guys.
I've always struggled with setting up Marshalls. The only one I've tried is the J-45 for clean rhythm.
These Pods are so time consuming because of the choice. (not a bad thing but it still takes a lot of time).
Unless you require an extraordinary variety of tones, you'll probably find yourself settling in on 3 or 4 models after a while. I like the blackface for cleans (Hi way occasionally too), Marshall for dirty rhythms, and Solano and Bogner Shiva for most leads.
 I agree i think i'll end with about 2 or 3 for each style.
Be consistent with your cabs too. I only use two different cab models for all my patches.
I have to say I just played 5 shows in a row with my HD500 and two Alto powered speakers and it just killed.
I use amps for a while and then go back to the HD500 for setting up tearing down going direct convenience and it never ceases to amaze me.
  • Upvote 2
I 2nd that.  I use the Dr Z cab and usually the U87 mic, or sometimes the 121.  Finding one good cabinet you like takes SO much of the guess work out.
My " fave" amps tend to shift slightly from time to time but I generally find I use the following to get a range of tones
Clean / Edge of break-up - Fender Bassman / Vox AC30 /  Soldano Clean
Blues -  Dr Z / Fender Deluxe
Crunch -  Plexi / Orange / Soldano Crunch
Hard Rock / Metal - JCM / Park / Treadplate
Also, for a slightly different flavour in the Clean / Edge of break-up tones, I will use the Divided by 13 / Supro / Gibtone and Fender Champ.
Hey Titchy
Yeah, I find the Marshalls ( and Park ) Models the hardest to dial in and I find that they are the amp models that I have to change cabs/mics on the most to get them to sound better ( I also need to use one or two Parametric EQs after the mixer block to dial out the "fiizzy" frequencies )
A little more patience needed for those amps but they can be dialled in pretty nicely.
Oh yeah, I forgot to add, the Marshall/Park models seems to respond better with the gain dialled off to a light crunch and a OD/Distortion pedal in front to bring the gain up to the required level.
So far the only amp I like consistently is the AC 30, both for clean and dirty.   I know this is due to some mistakes/oversights I'm making in settings and/or cabinet/mic choices.  The Blackface and Divided models have weak output.  At first glance the Marshall's are muddy.  I have the vintage pack but don't use any of them.
HD Vintage Pack   Model Name Modeled After Jazz Rivet  Roland® JC-120 Small Tweed Fender® Champ® (Tweed)      Mandarin 80 Orange® OR80 A30 Fawn Nrm VOX® AC30 (Fawn Normal Ch.) A30 Fawn Brt VOX® AC30 (Fawn Bright Ch.) Line 6 Acoustic Line 6 Original Black Panel Pete Pete Anderson Custom  Roland® JC-120 2x12 CAB   Fender® Champ® 1x8 CAB
My favourite amp models are Fender Baseman Normal (Tweed B-Man Normal), Fender Twin Reverb (Blackface Double Normal), Mesa-Boogie Dual Rectifier (Tread plate), Soldano 100 Clean, Vox AC-30.
From the HD Fully loaded bundle, I really enjoy the following: Remastered Marshall JCM800, Orange OR80, and Roland JC-120.
