Knowledge base links broken
jandrio
Links btween "POD HD500X/HD500 Pedal Calibration" <--> "After POD HD500X/500 Flash/Re-Flash/Update: MANDATORY Global Settings Reset!" not working.
***Please Note: Re-calibration of the POD HD500's expression pedal is necessary after performing a Global Settings reset. Instructions for how to perform a Global Settings reset is available here.
broken link: http://line6.com/community/docs/DOC-2222
***PLEASE NOTE: Please also make sure to re-calibrate the onboard expression pedal of the HD500 after performing the Global Settings reset.
Instructions: How to calibrate the POD HD500 Expression Pedal.
broken link: http://line6.com/support/docs/DOC-2223
