alessandro-rock Posted July 20, 2013 Share Posted July 20, 2013 my Pod Hd 500 dont run.. when insert cord the display become grey with white frame and doesn't work..also resetting..what can I do? Quote Link to comment Share on other sites More sharing options...
deguello Posted July 20, 2013 Share Posted July 20, 2013 Reload drivers through Monkey? Quote Link to comment Share on other sites More sharing options...
alessandro-rock Posted July 21, 2013 Author Share Posted July 21, 2013 yes but doesn't work Quote Link to comment Share on other sites More sharing options...
mazuwa Posted July 21, 2013 Share Posted July 21, 2013 First of all I would check the power. Can you measure 9V DC (=) output? If you connect your POD over USB at your PC and open Monkey, will Monkey show you anything, or can HD500 Edit read your presets? >If they can, the display would seem to be defect. Think that a full reset also means to reinstall the firmware. Connect you POD over USB and hold down the black round multi-function button to the right side and power up. It should then boot up in Safe Mode. Can you now read the display here? > If you do, then continue firmware update with Monkey and finish with firmware reset and pedal calibration. > If you don't, maybe the board is defect or the power still is not ok. Try to exchange the power cable (exactly 9V DC and at least 3A, e.g. Line 6 DC-3G). If this doesn't help, bring it to a repair center. 1 Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted July 21, 2013 Share Posted July 21, 2013 First of all I would check the power. Can you measure 9V DC (=) output? If you connect your POD over USB at your PC and open Monkey, will Monkey show you anything, or can HD500 Edit read your presets? >If they can, the display would seem to be defect. Think that a full reset also means to reinstall the firmware. Connect you POD over USB and hold down the black round multi-function button to the right side and power up. It should then boot up in Safe Mode. Can you now read the display here? > If you do, then continue firmware update with Monkey and finish with firmware reset and pedal calibration. > If you don't, maybe the board is defect or the power still is not ok. Try to exchange the power cable (exactly 9V DC and at least 3A, e.g. Line 6 DC-3G). If this doesn't help, bring it to a repair center. excellent long distance troubleshooting Quote Link to comment Share on other sites More sharing options...
