What Guitar Emulation You Use?
I am all over the place. I use the tele LP and a custom model I made called a Davison SG. I replaced position 2 and 4 in the LP model with a bridge SG in 2 and neck SG in 4.
It sounds crunchier and bitier and palm mutes sound nicer. Basically the LP junior body with LP humbuckers backed up towards the bridge a bit.
I use a combination of stock models and ones I customized in workbench:
Stock:
tele bridge
Tele middle
Strat pos 2
Strat pos 4
Strat neck
LP goltop bridge
LP custom neck and middle
Gretsch middle
LP junior bridge
LP junior neck
LP junior middle
Semi bridge
Jazzbox neck p90
Jazzbox neck humbucker
acoustics
sitar
Custom:
Tele filtertron bridge
Tele filtertrons middle
tele thinline p90 neck
tele with tel bridge and filtertron neck in mid position
tele with tele bridge and minihum neck
tele with dearmonds middle
Strat with mini hums pos 2
LP with PAF and a minhum stacked directly on top wired in series for a fatter sound
LPcustom neck
LP filtertron bridge
Semi with  mini hum in neck. . .a favorite
Semi with mini hums middle
Stock:
tele bridge
Tele middle
Strat pos 2
Strat pos 4
Strat neck
LP goltop bridge
Gretsch middle
LP junior bridge
LP junior neck
LP junior middle
Semi bridge
Jazzbox neck p90
acoustics
sitar
Custom:
LPcustom neck
Wow that's a lot. At least you can say to your girlfriend that it was a good use of your money :)
I can make an SG? Nice I'll try this after learning how workbench works.
Luckily the GF gets almost as excited as I do when I get new gear. The fact that I will soon have 6 JTVs doesn't bother her at all. Nor does the expense of transplanting most of those JTVs. . . .lol. . .
"Special Junior" with bridge at .89" and neck at 4.85", in series, in phase.
I modeled it after my Davison SG with A/B comparisons. Was pretty spot on.
A Les Paul Jr is a bit thinner than a Les Paul, and the SG is around the same size, so it gets rid of the excess chunkiness of an LP and gives it more bite. Sounds really great with high gain stuff and palm muting sounds great on it.
Really nice humbucker tone if an LP is a bit too fat and chunky sounding for you sometimes.
https://dl.dropboxusercontent.com/u/21663288/workbench/SGnew.zip
