Helix Bug Reports
HonestOpinion
Think I've got something weird on HX Stomp XL (v3.02 - is this even out yet? Just an XL patch?) and Command Center. I've mapped snapshots 1-3 to the bottom row of footswitches for patch 01A. Works fine until I use mode switch to enter patch mode. When I switch back to stomp mode, the red footswitch light that corresponds to the A preset (FS5) stays on. Seems to function ok, but it's an annoying visual.
After some more testing, it seems like it happens any time the preset footswitch shares the same switch with a CC snapshot. So if patch D (FS3) has a snap on FS3, it will stay red when switching back to stomp mode. But if it has a CC snap on FS2, the light goes away when you switch.
Also, it would be cherry if the current snapshot switch could be lit up white to correspond with the screen. So if my snapshots are 1-2-3 and I was using #2, footswitch 2 would light up, etc...
Have owned Helix lt for a little over a month it has v3.01 installed.. i have 5 of my own presets made 3 using  capo type tunings ( capo1 first fret capo 2 second fret ect) I use my variax 59 with my helix... when i switch from capo 1 preset to capo 2 preset the screen shows that the change was made from 1 to 2 but the sound has not changed from capo 1!!... this happened live so i panicked an pressed the custom button on my variax on and off and was able to change the sound to capo 2 ( the whole time it was showing capo 2 on the helix..... Any ideas
Have a Helix. Updated to most current version as well as HX Edit 3. Running a Variax through it.
Was playing last week and the sound started to rapidly cut in and out. Eventually the audio just went away.
Did a hard reset and loaded a backup. Seemed to work better until I played at a church service. Rehearsal was fine and I left the device on until the service started (Half hour or so from the end of rehearsal). Came to play and no audio. Nothing. Turned it off and back on...still nothing. The tuner was seeing audio from the guitar, just no output.
Solutions?
Solutions?
I've been dealing with the same thing on one specific Snapshot in one specific preset. I have an Essex A30 patch which functions perfectly fine in Snapshots 1 & 2 (Clean and Crunchy Breakup respectively). When I go to Snapshot 3 which has the amp with full gain and master volume, the sound will slowly choke out similarly to if the input signal is dropping steadily. Eventually it'll reach no audio at all but often switching Snapshots seems to correct it momentarily as going back to Snapshot 3 works perfectly fine. Until it does it again. I once left it on this Snapshot for an extended period and the audio was gone entirely from that and other presets. Luckily mine worked again after turning it off and on again.
The latest 3.1.0 release notes stated there is a fix for the Snapshot bug when changing presets related to the midi CC69 message:
  • MIDI Snapshot changes on CC69 that are received during preset loads will now be buffered and executed once the preset load is finished. This means that you can send a MIDI Snapshot change immediately after a PC message to effectively load a preset with a different Snapshot than it was saved with.
For me this simply still isn't working. I'll be going back to 2.9.2 when this feature was still useable.
Reply to my Support Ticket:
From one of our software engineers:
âSo this technically does work, but there seems to be some sort of thread priority bug. I am seeing that even when the CC69 is sent after the PC, the actual time it takes to load the preset can be longer than the CC69 being received depending on what is in the preset, which would result in the snapshot not being loaded as expected.
Using the wait parameter in command center set to 150ms or higher would avoid the issue. Or if an external device has a wait feature, using it there to send the CC69 to Helix/HX would work as well.
To Clarify, it is the CC69 that should be set to wait 150ms or so, not the PC message.â
IOW - there's a new WAIT parameter in Command Center, but if using an external controller, it must be capable of adding it's own WAIT command.
EDIT: I haven't had a chance to try this yet, but I'm thinking that if you use CommandCenter to assign the Preset/Snapshot load to a FS using the WAIT command, then trigger the FS from the external controller instead of sending the PC and CC, that might work I'll try it later and report back.
EDIT EDIT: Of course that doesn't work. What was I thinking? Need more coffee.
  • Thanks 1
Hi
I just did an update from 3.01 to 3.1 Everything works fine except for the Preset bank selector on the pedal. I cannot not select preset banks (push down on preset knob and rotate to select bank) I can selct it using HX edit but no response from knob on pedal. Have I left out something?? Installed as per Line6 instructions. Can I do a roll back and try reinstalling 3.1 or is this a potential bug?
42 minutes ago, djmizzi said:
Hi
Are you doing this:
Push knob and release
Joystick left so only the banks are showing
Rotate knob to select bank
If YES Then do a factory reset.
If that doesn't fix it open a support ticket.
It's not a bug, as there's no such problem on mine.
Thanks rd2rk
Much appreciated. I did a factory reset, installed 3.01 again then upgraded to 3.1 and noticed same issue until I pushed harder on the preset button. It turns out that it was probably ok the whole time but it needed a firm push to activate. Maybe just adjustment but its going fine. Thanks for your quick response:-D
Upgraded HX Stomp to 3.10   At least some of the guitar presets have no reverb.   When I create a new patch the reverb works just fine.
Not a major issue as it's pretty easy to create a preset, but I do usually like starting from the factory presets.
I've done a couple of factory resets with no change.
Anyone else seeing this?
I did submit a support ticket.
Usually, when weird stuff starts to happen, the factory reset will blow the bugs out.
After you updated did you do a factory reset, and restore from backup, and ensure that you are using HX Edit 3.10?
This is the recommended procedure after updating.
Hello,
I updated to 3.10 and am getting some black boxes obscuring the text showing the preset name.  This box blocks viewing of the screen info in that area and is not preset specific.  some presets will have and others won't.  It does not appear to affect the sound, but I'm mostly playing from the couch into an iPad so who really knows.  I did do the factory rest and backup as the instructions suggested.  I'll see if it persists and may try another reset if it persists.  Image shows missing part of screen in my "B:Fake Bass preset".
Do another factory reset. If that doesn't fix it, open a support ticket.
Just to let you know, if you'd not know, until 3.01 fw i was able to change snapshot after PC between 135 ms (using disaster area midi baby 3). with  fw 3.10 using same patches and same configurations and gears i've been forced to set at 155ms.
I've noted as you say that this value depends of the weigth of called patch.
So the added buffer in this release has got worse than before.
Hope it can be useful for you debug activities ;-)
thanks
  • Thanks 1
Found a couple of bugs with the 'File' --> 'Extract Files From Backup' function in HX Edit. Was hoping some other users could confirm them and if so I will create a ticket.
Hardware: Helix  Floor
Firmware/Editor: Firmware 3.10; HX Edit 3.10
OS: Windows 10
Bugs: 'Extract Files From Backup'
I noticed two bugs in the 'File' --> 'Extract Files From Backup' function in HX Edit. At least on my Helix. Not sure if these bugs will show up on every HX device or even on every Helix as my setlists are almost six years old now and are full of presets that have been through almost every firmware upgrade. Anyway here are the bugs:
One bug is that it does not seem to be working consistently if you just try to extract one setlist. When you do that you may just get an empty directory with a file named info.txt. Or, you may get a proper extraction but depending on which setlist you selected you may also get additional setlist extractions that you did not select. The extract seems to work properly however if you leave all the setlists selected for extract.
The second bug is quite minor. For some reason some of the empty presets named (by default) 'New Preset' don't seem to follow the naming convention properly and just end up with the preset number. I suspect this could be related to if those new presets slots were previously used and then had a blank "New Preset" copied back to them, or perhaps the name of the preset before them breaks the naming convention. Just speculating though.  Again, not a showstopper but a bug nonetheless.
Hardware: HX Effects
OS: MAC OS 10.15.7 Catalina
Bugs:
In a preset, I assign buttons to snapshots with Command Center. No efx have buttons assigned. 3 of the buttons behave as desired. You click on the button and the snapshot comes to life. One of the buttons, #3 in this case, requires 2 presses to activate the snapshot... the weird part is: after I select the preset it works fine the first time. Every subsequent time after that requires 2 presses to activate the snapshot.
Very strange behavior. I don't know if it's a new problem because I never used snapshots before 3.10.
I know I could use snapshot mode and not even use command center to do this, but I have a couple of momentary efx I want to turn on and off for this patch.
here's a video of it.
https://www.dropbox.com/s/3d4v93o3gra2qni/HX command center bug sm.mov?dl=0
UPDATE:
I swapped the snapshot to button 1 instead of 3 and now it works perfectly. Does that mean my 3rd button is messed up or can anyone else duplicate this behavior?
On 3/7/2021 at 6:22 PM, Guitarmaniac64 said:
Helix Floor Tuner
When i choose offset tuning and change the setting to TT Thidell Formula 1
E = -1
A = 0
D = +2
G = +4
B = -1
E = -1
And then do a backup so when i restore the backup the D is always set to = 0 instead of +2
It happens every time i do a backup (I have lots of backups as we have so few IR slots :( )
Luckily i am aware of the bug so i change the D to +2 immediately after the backup is restored.
Still present in FW 3.10 plz fix this when you got time
There is some true tmepered players who use Helix dont forget us.
Today I set up 2 no. foot-switches within command centre to control snapshots; next and previous.
Whenever I cycled through the snapshots, I was presented with the command centre screen and has to manually press home to go back into the preset. This is not workable in a live situation.
I am a new helix floor user on firmware 3.10 so I’m not sure if this is exactly a fault.
I set my two external switches for Snapshot Prev/Next on my Stomp, no problem.
On my Helix Floor I set up two Stomp Mode Footswitches for Snapshot Prev/Next, no problem.
Perhaps if you stated which device you're using and attached your Preset I can figure out what's wrong.
EDIT: Sorry, you're using a Helix Floor. Just attach your preset and I'll have a look at it.
There is a 3.11 version of the firmware out now so that is what I tested on. Same question as rd2rk as to what "2 no. footswitches" is referring to?  Can also confirm though that using global settings 'Footswitches' --> 'Up/Down' Switches' = "Snapshots" is working normally, can't replicate your bug.
Update: Just noticed you set up two additional switches for snapshots in Command Center. I will try that next.
One thing to be aware of is if you have the global settings 'Footswitches' --> 'Stomp Select' = "Touch" and you touch a footwitch that is assigned to a CC value that will bring up the Command Center screen as you observed. Stomping on it with a shoe on(or wearing gloves :-) for example does not do that so unless you are playing barefoot it should not impact your live performance.
If you find this inconvenient during editing you can always set 'Footswitches' --> 'Stomp Select' = "Off";  at least while you are editing your presets but that brings with it the downside of not being able to use the touch capacitance to switch the focus to a footswitch assigned block.
  • Upvote 2
7 hours ago, Ostrovsky said:
In the latest firmware, I found a problem. On any overdrive sound (effect or amplifier), there is a parallel sound like ring modulation. Very well heard in headphones on individual notes above 12 fret.
Before posting something as a BUG, it's best practice to first find out if anyone else has the problem. If it's actually a BUG, then EVERYONE will have the problem.
That is NOT the case here. You should probably do a factory reset, then examine your presets, then open a support ticket.
I just bought a new Helix Effects and now I think I have a broken unit. I have this problem, when I use 4-cable method with my tube amp:
When I use delay and volume boost at the same time, I get weird lower octave sound that makes using delay (or boost) useless. When I use only delay or only volume boost everything's ok. I have tried every possible scenario: for volume boost I have tried MXR micro amp in HXFX loop 2, after HXFX etc.  and also gain block in HXFX after and before delay for about 6db volume boost. Also tried to boost delay's volume in HXFX, tried eq-pedal block with only volume boost etc. it's all the same weird sound.
Nothing's clipping and in global settings-->in/outs I have everything set to instrument, it works that way best with my amp (Marshall Silver Jubilee 2525H with -10dbv FX-loop). I have tried every possible variation with in/out settings, and they all have the same problem. I have recorded only amp and amp with HXFX 4CM in Pro Tools and with those "all set to instrument" in/out settings those recordings sound almost identical and they have almost the same volume in my daw (only amp has -8,8 db  peak and amp+HXFX -8.6db peak, both recorded at the same -20 to -15db levels with amp and Reactive load+ir to daw). In my 4CM preset I have Loop1 block's all volume levels at 0 (and that way it's almost exactly the same output level than it's with only amp and guitar)
There's this same issue also if I have use my Flashback delay pedal in HXFX loop2 and try to boost volume in HXFX like mentioned before. So now I have to choose whether I use only delay or only volume boost for my guitar solos.
I've been playing guitar semi-pro for more than ten years, owned Kemper before and know something about gain staging, recording etc. so I've tried a lot different ways to try to get this work.
Here's a dropbox-link for the clip I recorded about this issue: https://www.dropbox.com/sh/n0k8zbkvi3caqqu/AABAmAS6r0Bjxryc83fqU3uja?dl=0
In this clip at first the gain block is on and about 6 db boost, then there's boost+delay, then only boost and then boost+delay off.
I have version 3.11. in my HXFX, I've triple checked the cables, gain stages etc. Hope someone could help me with this!
On 3/24/2021 at 6:40 PM, chugchug said:
Hey all,
Brand new Helix LT owner here running into a really frustrating problem.
After opening my LT for the first time, I connected it to my Mac (running OS SIerra), and attempted to update through the Line 6 Updater. About halfway through, it told me that the update failed.
I did read the prompts prior to beginning the installation that said I would receive error messages and helix would reset, but mine never did. Instead, it's stuck on an update screen that reads "Updating UI MCU Firmware, please wait. Do not power off the unit."
I waited about 40 minutes from this point to decide that something was wrong, so I started powercycling, attempting factory resets etc and nothing! It just returns to the same update screen. I'm incredibly frustrated. Has anyone dealt with this issue?
Same thing happened to me yesterday at soundcheck, Sea World Orlando. Had to run to GC and buy another Helix. This is after running it every day for a week, playing through it, and turning it off at the end of the day, just to make sure there would be no problems on the first gig in 15 months. This is after updating to 3.10 almost 2 weeks ago (yes, I went through 3.01 first) Definitely not my first update, as I've owned my Helix for 5 years now and have relied on it for touring for the entire time.
Helix Native Tremolo FX Sync?
Have you noticed that the tremolo phase doesn't sync very well to the DAW tempo?
What I mead by that is every time you start the playback the tremolo phase doesn't fall in the same place - sometimes it's a musical length off - upbeat instead of downbeat, sometimes it seems just out of sync. The time interval is correct though, just starting at an arbitrary time.
I don't know if it's a bug, an unfortunate feature, is it just for me or for everybody?
Im using Reaper on Windows 10.
EDIT: I tried also automating the bypass of the tremolo, but this doesn't seem to have an effect on the phase of the tremolo.
51 minutes ago, Jokerwolff said:
Hello !
I've updated my HX Effects but can't find any of the new 3.11 effects like the dynamic hall that I'd love to try so much. Is there any problem with my unit or with the patch ?
 Update HX Edit as well.
5 minutes ago, P-air said:
Hi.
I updated both the HX stomp and the HX edit to 3.11 and i do not see any of the effects in HX edit.
Regards.
You may have thought HX Edit updated, but it didn’t. Delete the old installation package and try again.
  • Thanks 1
OS: Windows 10
Thanks to AgFX for bringing attention to an additional bug that renders this command unreliable until it is fixed. The preset files the 'Extract Files From Backup' utility  extracts fail when you try to import them back into your device with the following message: "-8103 - Target is incompatible".  Perhaps there is a manual edit that could be done to the extracted preset files in the meantime that could get them in the proper format for import but who wants to have to do that. I opened up a Line6 ticket with all three of the bugs discovered so far.
Update: AgFx posted that he went ahead and figured out the manual edit required for the preset files produced by the extraction and was able to import them so they do provide some measure of usefulness but for most users this utility still needs to be fixed.
Firmware/Editor: Firmware 3.10; HX Edit 3.11
Bugs:
In HX Edit -
Control click on a preset name, COPY
control click on another preset name, PASTE
or
option drag a preset to another slot to copy it
CRASH!
On 4/22/2021 at 3:35 PM, gsking1 said:
Hello,
I had the same problem after installing 3.10! Today I installed te latest 3.11 version. Hope it is gone now.
14 hours ago, Sixty40 said:
I've found a MIDI feedback loop issue with my HX stomp.
I'm using Stomp to control an Ableton session with command center. I use a single Midi note on message (channel 1, momentary), which is mapped to two buttons in Ableton's session view: "Scene Launch" and "Select Next Scene". Some of these scenes contain clips in Live, which trigger snapshot changes in the Stomp.
The issue is that sometimes when I hit a new scene with a snapshot change command, Stomp changes snapshot and re-sends the Midi message from command center without me hitting the button. This results in Live skipping a scene, and triggering the one below the scene that I intended to play. I think there must be some kind of Midi feedback loop happening here.
I've noticed that when I reset the pedal, it stops happening for a while, but the issue has returned numerous times, so there might be a bug here.
Thanks a bunch for your help :)
Before posting a BUG, you need to ask for help and VERIFY that it can be reproduced (or resolved) by others.
I suggest that you delete this bug report and post it as a help request in the regular Helix thread.
If you leave it here it will most likely be ignored because NOBODY in support has time to troubleshoot a complex configuration involving a third party product.
I, OTOH, have time to spare to look into an interesting problem involving MIDI and two products that I use.
When you re-post it, include the HXS presets needed to test the problem, and a more detailed description of how your basic project is set up.
Without those, the number of variables is infinite, which is why no one in support will pay any attention to your issue.
Creating parallel path on 1B or 2B causes dry guitar to override settings
Helix LT 3.11
HX Edit 3.1 on Win 10
[Method]
- Start with a new preset. Change input to something not in use, just to verify you can start with no guitar present (e.g. USB 1/2 or Return 1) then change back to Multi or any working input.
- Add any block to Path 1A (e.g. Amp+Cab to easily hear alteration to the sound).
- Add a second block to Path 1A.
- Drag second block to create Path 1B, then drag Split and Merge points to Path 1B to create fully parallel path.
- Delete block in Path 1B, which will remove the Path.
- Delete block in Path 1A, reverting to empty preset.
[Result]
- Dry guitar is now present regardless of input settings, output settings, blocks or paths created.
Further notes from testing:
- Only tested on HX Edit, I don't know if this also happens when working on the unit directly.
- Tested with a Variax using VDI cable (models and mag) and 1/4" (mag only).
- Did a factory reset/restore from backup after first noting the issue, but haven't tested on another unit.
- This only happens when you create a fully parallel second path on either Path 1 or 2.
- It sounds like an obscure issue, but it has potential consequences. For example if you create a parallel path on an existing preset, there is no way back once you save it - except to restore your preset from a backup or start over. You are otherwise stuck with the dry guitar on your preset.
- If you're feeling especially evil, prank a friend by doing this to all their blank presets and watch them slowly descend into madness.
This appears to be a long-standing issue since launch. LFO is not properly reset/synced. This is also an issue in the hardware units - LFO is not reset via MIDI (either tap tempo or clock sync) effectively making it impossible to use LFO-based effects consistently (or worse yet, when double tracking). I have raised this many times and it's been consistently ignored by Line 6.
Here's a video to demonstrate it (watch with headphones):
Here's a waveform of the rendered clip:tremolo-sync-bug.thumb.jpg.d98d26933866cbb820acf351512c107f.jpg
1 hour ago, rd2rk said:
I'm 99% sure that a solution to this problem has been requested on Ideascale, and more than once!
Go there, do a search and VOTE!
First of all, this is a bug, not a feature. A bug, that has been in the product since day one. I created a support ticket in 2018; it was even accepted as a bug by Line 6, quoting the representative:
I confirmed this to QA/developpement as confirmed bug, should be fixed in one of the next updates,
but i have no timeline when
It's been 3 years since...
