rsto10 2 Posted October 12, 2015 Has anyone figured out how to customize the scribble strip for a switch that only controls multiple parameters and not blocks. For instance, I always leave reverb on, but one switch controls both decay and mix for two different levels of reverb. Since the switch isn't assigned to a block, I can't figure out how to customize it. Thx! Quote Share this post Link to post Share on other sites
cacibi 7 Posted October 12, 2015 Page 39 of the manual: "Customizing a Command Footswitch Label" Quote Share this post Link to post Share on other sites
rsto10 2 Posted October 12, 2015 I know how to rename a strip when assigned to a block/effect. What I can't figure out is when it's only assigned to multiple parameters OF an effect. It just says Multi and when you go to rename it, it's grayed out because there's no block assigned. Make sense? Quote Share this post Link to post Share on other sites
cacibi 7 Posted October 12, 2015 Yes - I understand. Sorry - I have not tried this yet but - what I read the manual as saying is: when you have assigned parameters to a switch, you have basically made it a Command Footswitch, not a Block/Effect footswitch. So you have to customize it from the Command Center screen. Not the Footswitch Assign screen. 2 Quote Share this post Link to post Share on other sites
phil_m 4,539 Posted October 12, 2015 I know how to rename a strip when assigned to a block/effect. What I can't figure out is when it's only assigned to multiple parameters OF an effect. It just says Multi and when you go to rename it, it's grayed out because there's no block assigned. Make sense? Makes perfect sense... The answer cacibi gave you above is correct. You have to go into the Command Center and use the custom label function there. I can attest to the fact that it works. I've done it in a couple of my presets. 1 Quote Share this post Link to post Share on other sites
rsto10 2 Posted October 12, 2015 Ah Ha, I forgot about the whole command center part as I have't done anything with it so far. Thank you so much!! Quote Share this post Link to post Share on other sites
Digital_Igloo 1,107 Posted October 13, 2015 Sorry, there wasn't room to place a "Customize" button on the Controller Assign page. The Command Center page is currently the easiest way. There's nothing special about labeling a scribble strip from Footswitch Assign vs. Command Center—just two ways to get to the same window. Quote Share this post Link to post Share on other sites
cordelero 2 Posted October 18, 2015 I think it would be fantastic if there was a separate page where you could manage all the footswitch and controller assignments for a particular preset without having to move the joystick around. This would be especially helpful if you have complex multiple parameter assignments and just want to tweak it a little bit. Right now it feels like I'm always one wrong move from completely screwing up my patch. Quote Share this post Link to post Share on other sites
Digital_Igloo 1,107 Posted October 19, 2015 I think it would be fantastic if there was a separate page where you could manage all the footswitch and controller assignments for a particular preset without having to move the joystick around. This would be especially helpful if you have complex multiple parameter assignments and just want to tweak it a little bit. Right now it feels like I'm always one wrong move from completely screwing up my patch. If something's assigned to a switch, you don't need to use the joystick at all. Just touch the switch. If multiple items are assigned to a switch, touch the switch repeatedly. Way faster and easier than providing some complex assignment matrix view. Quote Share this post Link to post Share on other sites
trinitypc 10 Posted November 23, 2015 Sorry, there wasn't room to place a "Customize" button on the Controller Assign page. The Command Center page is currently the easiest way. There's nothing special about labeling a scribble strip from Footswitch Assign vs. Command Center—just two ways to get to the same window. What about adding a second page? Then we would just use the "page >" to get to it. Quote Share this post Link to post Share on other sites
