Overturept Posted October 14, 2015 Share Posted October 14, 2015 Hi, one more, i saw various people reporting the same issue but almost had solution and unfortunally i didn't.. I have a Variax 600 and works fine, and i bought the XPS, TRS Cable and the USB interface. When i connect the variax to the interface and interface to computer both leds blink green and the interface is detected, the variax isn't. I've tried with other computer, other USB port's, other OS's and nothing. Tried with batteries and XPS, only batteries, only XPS various combinations and with no success. I've opened the guts and made continuity test's between the RJ interface on the guitar with the cable connected to the other end of the USB interface wich seems that the problem isn't of the both connectors and the cable. I've saw a pinout diagram to connect the guitar to the computer via RJ-MIDI, i did the piout but nothing, but i dont know if anyone tested and if anyone did, can provide me the diagram of midi to ethernet just to confirm i did it right. Anyone have more ideas? Regards. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted October 14, 2015 Share Posted October 14, 2015 Hardware issue, needs to be troubleshooted at a Line 6 authorized service center. Quote Link to comment Share on other sites More sharing options...
Overturept Posted November 3, 2015 Author Share Posted November 3, 2015 It was the USB interface problem. Thanks. Quote Link to comment Share on other sites More sharing options...
G1HGD Posted January 31, 2016 Share Posted January 31, 2016 I have just bought a Variax 600 and have the same problem as descibed above. What was the cure in the end? Do i need to send the USB box back? Thanks. Mike. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted February 1, 2016 Share Posted February 1, 2016 Don't use a USB hub device. Just the Variax interface device alone. Quote Link to comment Share on other sites More sharing options...
