How to get the HD500 expression pedal to control the Drive Level?
seratone
Can anyone explain how to get the HD500 expression pedal to control the Drive Level of a particular Amp model - using the editor? (not the knobs on the top of the unit) I know this can be done - but there appears to be nowhere online that explains how.
That didn't work - I went to controllers and set it up this way: Model=Brit J-800, Parameter=drive, FS Assign=EXP TOE SWITCH, CONTROLLER=EXP-1. Minimum 17%, Maximum=27% (these settings are 'White' on the controller page). I also tried adding a volume/pan pedal after the mixer to the effects...no go - could my HD 500 possible have a defective expression pedal?
I also calibrated the peadal using these instructions :
http://line6.com/support/page/kb/_/pod/pod-hd500-hd500x/pod-hd500xhd500-pedal-calibration-r161
When I set the expression pedal as I did the the post above - as soon as I depress the exp pedal to it's maximum - its entry in the controller section dissappears.
