Sign in to follow this
tommasi
Opto trem speed: no tap?
Finally got myself a helix!
I noticed that the opto trem effect does not let you set the speed via tap, unlike the other tremolos.
It seems strange, do you think it's intentional?
Thanks -- I did use search, but as I searched for "opto" and not "optical", there were no results. I believe it was called opto on the hd500, or at least that's what I thought.
I've noticed that with at least the ubiquitous vibe, 1/1 and 1/2 don't seem to work.
It could be that there's a max time for the rate for that, so those values might put it over for most tempos. Some of the delays are like that.
I was wrong, it's not 1/2, but 1/2 dotted and 1/1. 1/2 sounds almost exactly the same as 0.1 for the rate, so it makes sense what you said above.
