anydmusic Posted October 17, 2015 Share Posted October 17, 2015 Done all the obvious things like use a different cable and reset the amp. Contacted support they could not help. Repair company says that they have never seen the problem before and sending it to them plus the non refundable investigation fee is nearly half the cost of a new amp. Desperate to know if anyone else has had this problem and can it be fixed. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 19, 2015 Share Posted October 19, 2015 What do you mean by 'stopped'? No output? Can't change tones? Quote Link to comment Share on other sites More sharing options...
anydmusic Posted October 19, 2015 Author Share Posted October 19, 2015 The FBV2 will not change the channel. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 20, 2015 Share Posted October 20, 2015 Have you tried a different connection cable? Quote Link to comment Share on other sites More sharing options...
anydmusic Posted October 20, 2015 Author Share Posted October 20, 2015 Yes I changed the cable. FBV2 works with all my cables and another Spider iii. Seems like I really am the only person ever to have this problem. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 21, 2015 Share Posted October 21, 2015 Can you change the channels manually with the buttons on the amp? If so, then the problem woudl seeem to be in the amp-cable connection, or in the software. Unfortunately, due to the age of the amp, it would not beworth trying to get repaired. Quote Link to comment Share on other sites More sharing options...
anydmusic Posted October 21, 2015 Author Share Posted October 21, 2015 Yes I can change channels on the amp, the problem is that it does not respond to the pedal. Quote Link to comment Share on other sites More sharing options...
anydmusic Posted November 6, 2015 Author Share Posted November 6, 2015 So the only way I could fix this was to buy a Spider iv. Unfortunately technical support could offer no help. Expensive solution. Just hoping that the Spider iv is more reliable than the Spider iii if not I just wasted a small fortune. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted November 9, 2015 Share Posted November 9, 2015 Unfortunately, old amps fail. Quote Link to comment Share on other sites More sharing options...
anydmusic Posted November 9, 2015 Author Share Posted November 9, 2015 Unfortunately, old amps fail. Indeed they do fail but not sure that I would call a 6 year old Spider III old and I have much older amps that still work. Quote Link to comment Share on other sites More sharing options...
HoopUte Posted June 25, 2016 Share Posted June 25, 2016 Hmmm, this may be similar to the problem my 9 year old Spider III 120 just developed. I use an FBV Shortboard MkII with it. Recently the expression pedal quit working. It won't even calibrate. Volume is stuck at zero, but you can get it to switch into wah mode but can't mess with the wah. I just tried a new Shortboard thinking it could be the sensor in it, but no change. I'm thinking the amp itself may be toast. The bad news is, this happened just before a gig, and I've got another one tomorrow. I can kind of limp through using the volume control on the guitar, but that's tricky after using a pedal for so many years. Quote Link to comment Share on other sites More sharing options...
anydmusic Posted June 25, 2016 Author Share Posted June 25, 2016 I ended up buying a Spider IV 75 to replace my Spider III 75 because it was cheaper than attempting a repair. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 27, 2016 Share Posted June 27, 2016 Yes, repairs these days on SS amps with processors in them can get expensive. Not like the old days when you could get a valve head re-capped, new power transformer put in for $100 by some guy working out of his garage shop. Like everything else electric/electronic it's all 'disposable'. :rolleyes: Quote Link to comment Share on other sites More sharing options...
BillBee Posted June 27, 2016 Share Posted June 27, 2016 One thing you can look at is check the ports and see if all the cat5 pins are still straight. If one is askew the signal path is broken, you might be able to line it up again. If you know the 2nd FBV is good and tried a different cable with no luck a bent pin on the amp is hopefully it. Wishing you some luck! B Quote Link to comment Share on other sites More sharing options...
