Bardo1984
Issues with UX1, Reaper and Windows 10
Hello everybody. I have the following problem. I have an old toneport UX1 (the Red/black one) and I have used it on various windows releases from XP till 7, and on various DAWs, last of all Reaper, always managing to install the right drivers and record, play etc etc..  Two months ago I updated to windows 10 and it was then that I experienced a seemingly critical problem, that I couldn't solve. Even with the latest drivers I can't hear no sound in reaper, I can't record no more, I no longer can use my device. This is really disappointing since the device is fully functional and I don't want to throw it away. I tried with all the buffering and sample options. No Way. While Reaper recognise the drivers, the playback bar gets stuck and the software often crashes...
Does anybody have the same problem or knows the solution?
Just for clarification you have green ticks in Monkey for drivers?
You are selecting the Line6 ASIO drivers in Reaper?
You are selecting the UX1 as your default device in Windows?
Is there an answer to this? I have tried everything stated above and then some and I can't get vst's to work in reaper or T6. Podfarm works fine as standalone but I can't record. Also when i I loaded the Vst's to T6, they loaded but it said they failed. Either way I cant get a signal from the Ux1 in recording software. It all worked fine until windows 10.
Select 16 bit 48000Hz for your bit/sample rate and see if that works.
Create an account
Register a new account
Sign in
Sign In Now
