sxross Posted October 26, 2015 Share Posted October 26, 2015 I was able to do this in the past, but have obviously forgotten some key element. I have a straight-through stomp-box configuration with no amp models. The signal chain is: Tube Compressor -> Conductor -> Chorus -> Distortion (several) I've had this in place for a while, but noticed that while I can activate the Conductor using the toe switch, moving the pedal does not do anything. This may have been something new in firmware -- I've updated that more recently than this patch. The L6 factory presets still work fine with the pedal and effect. Any help on what I may have done wrong is appreciated. The Conductor is set at 100% mix and the controller uses the toe switch to activate and the pedal position to control the effect 0-100%. Thanks! Quote Link to comment Share on other sites More sharing options...
sxross Posted October 26, 2015 Author Share Posted October 26, 2015 I gave it "one more try" and it worked. Not having an EXP-2, I'm not certain the significance of the LED turning from red to green when the toe switch is pressed. In any case, I made the changes in the POD-HD software. What may have worked was shutting the effect off by default and then uploading it (downloading it?) to the device. I guess I wish I knew what the real problem was so I could fix things on the fly. Quote Link to comment Share on other sites More sharing options...
napynap Posted October 27, 2015 Share Posted October 27, 2015 ...therefore the FX parameters assigned to EXP 1 will be controlled by the pedal only when the red led is on, and those FX parameters assigned instead to the EXP 2 will be controlled by the pedal only when the green led is on... hurghanico, thanks for clearing that up! I was trying to assign something to the pedal one day and couldn't get it working, but now I see why. Quote Link to comment Share on other sites More sharing options...
