anouchirvan Posted October 30, 2015 Share Posted October 30, 2015 Hi, it just hangs randomly and becomes really annoying since I have to reboot the computer. Nothing else do it not even disconnecting and reconnecting USB cable. By doing this UX2 never comes up and keep flashing. Anyone experienced this problem ? Any fix ? Just to make things interesting, while the audio out of iTunes stops (even the iTunes song's cursor stops advancing), that is, no audio gets out of any windows app which seems to mean UX2 crashed, there is a case where I can have audio working properly when using Reaper (a DAW for recording/mixing) to output the sound to the UX2's ASIO driver. This is very strange because all sounds getting through ASIO driver are OK (I can hear any mp3 track or instrument through Reaper) but those from iTunes (or any audio player) getting through Windows sound subsystem (before getting through the UX2 which is the default Windows sound output) don't work! Any idea what's going on here ? If only iTunes were more intelligent to let us choose the right audio device instead of using the Windows' default sound, I could turnaround this problem. In that case I'd choose my on-board sound card for iTunes and not UX2. But now, since I MUST use UX2's ASIO for Reaper I have to set the UX2 as the Windows default otherwise I could not hear other windows apps' sounds (iTune, etc.) I'd just hear sounds playing through Reaper Thanks for your help Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 30, 2015 Share Posted October 30, 2015 Update POD Farm, you should be running 2.5 Run the newest version of Monkey to get all your updates. Quote Link to comment Share on other sites More sharing options...
anouchirvan Posted October 30, 2015 Author Share Posted October 30, 2015 I just tried although I'm not heard any windows sound issue being resolved. But after updating the monkey itself, the monkey says it can't connect to line 6 server to check for updates !!! any other way to install the POD drivers manually ? Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 31, 2015 Share Posted October 31, 2015 You can go to the downloads page and download PF 2.5, and the drivers. Quote Link to comment Share on other sites More sharing options...
