davee1966 Posted November 8, 2015 Share Posted November 8, 2015 Hello, My Spider Valve mkii 112 makes no sound. One day I turned it on and the volume was very low. It sounded normal otherwise. The next time I turned it on there was no sound at all. The tuner works, so I know it's getting a signal from the guitar. There's no sound when I plug into the "power amp in" There's no sound from the "preamp out" into a mixer. It looks normal, the lights and LED are working, Seems odd that it makes no sound at all. Any ideas? Thanks. :) Quote Link to comment Share on other sites More sharing options...
Jberry75 Posted November 14, 2015 Share Posted November 14, 2015 I had a similar problem that you are experiencing, turns out there was a fuse inside of the amp that had blown. I took the amp apart and replaced the blown fuse on the motherboard and the amp starting working again. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 19, 2015 Share Posted November 19, 2015 Do not touch the fuse with your fingers while it is in the fuse holder,.... ... even with the power off. Capacitors will discharge into your fingers. It hurts like hell. Leave it to a trained tech with tube amp experience. If a fuse blows, then it means that something is wrong. Changing the fuse doesn't solve the source of why blew in the first place, so it will blow again at some point. Leave it to a trained tech with tube amp experience. Quote Link to comment Share on other sites More sharing options...
IronMosher Posted December 15, 2015 Share Posted December 15, 2015 I have a 212 and might be having the same problem. Would this cause the tubes not to glow? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 15, 2015 Share Posted December 15, 2015 If it's the power tubes,... yes. It's harder to see the glow of the pre-amp tubes. I usually use a laser thermometer to tell me what's what with them. Quote Link to comment Share on other sites More sharing options...
IronMosher Posted December 15, 2015 Share Posted December 15, 2015 If it's the power tubes,... yes. It's harder to see the glow of the pre-amp tubes. I usually use a laser thermometer to tell me what's what with them. I'm refering to the two tubes closest to the rear of the amp that are not in the metal housing. I looked through the manuals and couldn't find which tubes are which and I didn't have time to disasemble today. Regardless I might as well replace all my tubes while I'm at it since it's never been done. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 15, 2015 Share Posted December 15, 2015 Use the Sovtek 5881WXT matched pair. Quote Link to comment Share on other sites More sharing options...
AquaRegia Posted August 2, 2016 Share Posted August 2, 2016 Just another data point that may help future member with similar problems: I love my Spider Valve Mk i, so when I saw a good deal on a Mk ii, I grabbed it. I verified it worked and stashed it in my basement for about 6 months, until I had time to play with it. I turned it on a few days ago, and after a brief crackle, no sound. No hum, no "bad" noise - total silence. Lights on, tubes glowing, but no noise. I came here and read some topics, including this one. I checked the two fuses accessible on the back panel. I verified that the new speaker worked by outputting my old amp into the new speaker; I verified the new amp would NOT send a signal to the old speaker. I removed the 4 screws, pulled out the amp head from the cab and checked the two motherboard fuses - both fine. Next step - check tubes. Sure enough, one of the 12ax7b preamp tubes had failed, which I discovered by replacing them one at a time with old ones I had replaced and saved. Apparently a dead tube can look just like a good one (especially if, like me, you have little experience regarding what you are looking at). Quote Link to comment Share on other sites More sharing options...
dannymonzon Posted September 28, 2020 Share Posted September 28, 2020 I am having the same issues. One day I went to turn it on and nothing, no sound. Everything else turns on fine, I can control the amp with my foot pedal but no sound at all. If I turn it all the way up you can barely hear something there. I also hooked up my speakers to a different amp and they work just fine. I noticed that all of my tubes don't have any lights on them at all no yellow glow. I checked the fuse and seems to be ok. Checked with a meter and it measured 1.7ohms and beeped like it was good on my meter. I have not taken it apart yet, but why would all of a sudden all of the tubes not be working? If one is out will all the other ones not work as well? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 28, 2020 Share Posted September 28, 2020 "... why would all of a sudden all of the tubes not be working? " --- When were the tubes changed out last? What is the brand and tube numbers of the tubes in there now? Any servicing should be done by a Line 6 authorized service center who knows the product. These are not the all analog tube amps of old, they have to be handled a little different. Quote Link to comment Share on other sites More sharing options...
