ChaserHUN Posted November 9, 2015 Share Posted November 9, 2015 Hey After using the POD HD 500X with an Alto TS112A, I'm probably going back to real tube amp, and using the POD as a multi effect only with 4 cable method. On it's own it sounded amazing, but with a band, no matter how I EQ-d, or loud it was, couldn't keep really up with the real amps. Doesn't sound as good as the real deal. I've red stuff that with the 4 cable method the tone gets muffled etc? Any experience with this? I'm probably going to use it tihe a Valveking. and switch channels via midi. Quote Link to comment Share on other sites More sharing options...
MGblade Posted November 9, 2015 Share Posted November 9, 2015 i use my hd 4cm with my tube head, sounds great, didn,t noticed any "tone suck" there is some level signal loss with the effects return send of the hd, but that's solved by placing the effectsloop block after the mixing block and boosting the mixer by 6/8 db. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 10, 2015 Share Posted November 10, 2015 i use my hd 4cm with my tube head, sounds great, didn,t noticed any "tone suck" there is some level signal loss with the effects return send of the hd, but that's solved by placing the effectsloop block after the mixing block and boosting the mixer by 6/8 db. The FX loop has it's own dB boost, so you should be able to place it anywhere in the chain and level things out without messing with the mixer...in fact, on a few patches where I want to keep the same tone for rhythm and lead, that's what I use it for. Just plug the send straight into the return with a 3" cable, and boost it by about 3-4 dB. Quote Link to comment Share on other sites More sharing options...
MGblade Posted November 10, 2015 Share Posted November 10, 2015 only the effects return side has a boost , on the send you can only decrease the level, on the send you have to increase level for unity gain. there are many threats on this issue Quote Link to comment Share on other sites More sharing options...
ChaserHUN Posted November 10, 2015 Author Share Posted November 10, 2015 Also wondering, how would you boost your signal to get your rythm channel into lead? As my amp has only 2 channels. Before I used an EHX LPB-1 or my Memory Boy Deluxe to boost the signal as well. Quote Link to comment Share on other sites More sharing options...
MGblade Posted November 10, 2015 Share Posted November 10, 2015 there are a lot of ways to do this, screamer, studio eq(clean boost), a compressor, the boost comp, etc etc i use the parametric eq before front amp, "lows 40% highs 45% freq 45% Q 40% gain + 8 db"( you can sweep the freq and Q to youre own taste), this gives my amp a warm midboost for singing leads on the crunch channel and a satch like high gain lead tone on my lead channel. i use the studio eq at the end of my chain for a 4 db solo clean boost Quote Link to comment Share on other sites More sharing options...
