Helix and external Pedals Bug?
ultraknilch
When using an external pedal to control for example the volume, and using the amp relay out to switch channels on my amp, the external pedal only controls a range from 0 to 78%... as soon as I disconnect the cable controlling my amps channel, the external pedal has a full range again (0-100%)
Has anyone else discovered this problem? would be nice if you could try and see if your unit behaves the same way!
