Line 6 Monkey and Helix
daddydoodles
Why is there no Helix in the Drop-down menu for configuration in Line 6 Monkey?
The Helix does not use the Monkey software. You need to use the Line 6 updater application. It is in the downloads section under Helix at:
http://line6.com/software/
You will also want to make sure you download and install the Helix app and drivers as they will allow the Updater to see your Helix.
The Line 6 Updater is pretty much Monkey 2.0. I don't think any new products Line 6 comes out with from this point on are going to be using Monkey.
The thing that I appreciate about the Updater is that the program itself doesn't have to be updated whenever there's a firmware update.
